Histogram Stretch (and Shift T) does not work
Randlov
motherboard: Lenovo ThinkPad T550
processor: Intel Core i7-5600U
Video Card: Inte HD Graphics 5500
Hard_Drive_Capacity: 3513GB
Monitor/Display Make & Model: Lenovo. 15.5" 3K, IPSW, Multi-touch
Corel programs: PaintShop Pro X7 and X8 32/64 2019 2021
Post by Randlov »
Activating Histogram Stretch or the hotkey Shift T does not have any effect on the image.
(Histogram Equalize works fine).
I have to handle a very large number of old scanned b/w underexposed glasnegatives, so batch processing with Histogram Stretch is necessary.
I have tried to reset workspace and database without any change.
Windows 64, 64bit, PSP X8 64 bit 18.2.0.61.
Any suggestions?
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Histogram Stretch (and Shift T) does not work
Post by Forriner »
Theoretically (mine, I'm not an expert), histogram stretch is used to stretch a histogram from lowest values higher than zero to zero, and/or and highest values lower than 255 to 255.
If there already is a zero value present, the histogram can't be stretched to the left, and if there's a 255 value it can't be stretched to the right.
Perhaps Levels?
Jean-Luc
Hard_Drive_Capacity: 2 Tb
Post by Jean-Luc »
Hi Randlov,
for me, Equalize does a better job. I tried on an underexposed photo.
Streching works when pixels are grouped in the center of the histogram. If many pixels are grouped on the left or on the right, this command (Stretch) will be useless.
Randlov
Post by Randlov »
Thank you very much to both.
I checked with an image with a narrow histogram in the middle, and Shift T worked fine.
The images I am working on right now are scans of old underexposed glasnegatives where the histogram is concentrated at the right. In this case Shift E gives an acceptable result in 3 out of 4 cases.
Problem solved!
Peter
