ASP3 linux - bad magic on opening jpgs
Bugs & Suggestions
bin
operating_system: Linux
Post by bin »
So I fell for the upgrade offer and handed over money.
Starting ASP3, selecting folder - crashes.
Run from CLI
following output.
robin@mopsie:~$ /usr/bin/AfterShot3X64
Install Path: /opt/AfterShot3(64-bit)
LD_PATH: /opt/AfterShot3(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS:
I have SSE2
Bibble program arguments ("./AfterShot")
Linux does not support Commond Folder. Uses "/opt/AfterShot3(64-bit)/supportfiles"
Loading plugins
AfterShot2 Pro New key used. 20
AfterShot vers.: 3.0.0.148
Built on: "Fri Jun 24 2016"
Language: en
App Path: /opt/AfterShot3(64-bit)/bin/AfterShot
System Home: /opt/AfterShot3(64-bit)/supportfiles
User Home: /home/robin/.AfterShot Pro 3
Prefs Home: /home/robin/.config/Corel/AfterShot Pro v3.conf
Platform: Linux
Issue: "Ubuntu 14.04.4 LTS \n \l"
Kernel: "Linux version 3.13.0-92-generic (buildd@lgw01-52) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3) ) #139-Ubuntu SMP Tue Jun 28 20:42:26 UTC 2016"
Build Mode: Release
Product Name: "AfterShot Pro 3"
Registered Version
Initializing
Cpu Manager init: 2
**** Making CLManager
Got 0 platforms
OpenCL is disabled in low mem mode
"Could not select an OpenCL platform"
**** CLManager not initialized
tileSize: 512
"MemTotal: 3919336 kB"
Memory: 3
Asset: 2147483647 purge
Heavy Asset: 2147483647 purge
NoiseEngine: 150 purge
NoiseEngine: 75 cache (50 min)
Histogram: 24 purge
Histogram: 12 cache (12 min)
PluginData: 9 purge
PluginData: 9 cache (8 min)
ImageMaster: 600 purge
ImageMaster: 300 cache (50 min)
NContainer: 2147483647 purge
Path: 2147483647 purge
Path: 2147483647 cache (2147483647 min)
RawData: 25165821 purge
UncompressedRawData: 9 purge
UncompressedRawData: 9 cache (8 min)
Version: 600 purge
Version: 300 cache (50 min)
PerfectlyClear: 6 purge
PerfectlyClear: 4 cache (4 min)
TileStack: 24 purge
TileStack: 12 cache (12 min)
StackTile: 3000 purge
Created 626 buffers of 857472
FALLBACK to 1252 tiles
BImageTile: 1800 purge
BTiledImage: 2147483647 purge
RegionImageTile: 3000 purge
Allocate Asset manager
Option group - "" - already contains an option with name - "TIFFTAG_AFMODE"
Option was not registered.
Option group - "" - already contains an option with name - "TIFFTAG_FLASHMODE"
Globals: systemhome /opt/AfterShot3(64-bit)/supportfiles
Globals: userhome /home/robin/.AfterShot Pro 3
==================== Plugins =====================
Name:
Identifier:
Version: 1.0.0
Path:
Name: Black and White
Identifier: com.corel.BlackAndWhite
Version: 1.0.0
Path: <System Home>/plugins/Black and White.afplugin
Identifier: com.corel.equalizer
Version: 1.0.5
Path: <System Home>/plugins/Equalizer.afplugin
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_canonlenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_nikonlenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_pentaxlenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_minoltalenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_olympuslenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_panasoniclenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_sonylenstable.txt
load lens IDs from table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_samsunglenstable.txt
Couldn't open lens table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_fujifilmlenstable.txt
LensDB - Loading lens entries from "/opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/lens-cameras-db.xml" | Cameras found: 543 and updated: 543 | Lens found: 0 and updated: 0
New lens exif id/value info: "4 231" | "Tamron 16-300mm f/3.5-6.3 Di II VC PZD B016 Macro" added into lookup table: "Pentax"
New lens exif id/value info: "00 54 44 44 0C 0C 00 00" | "Nikkor 35mm f/1.8G" added into lookup table: "Nikon"
New lens exif id/value info: "00 54 44 44 0C 0C 00 00" | "Nikkor 35mm f/1.4 AiS" added into lookup table: "Nikon"
New lens exif id/value info: "66 40 2D 44 2C 34 6C 02" | "Nikkor 18-300mm f/3.5-6.3G DX ED VR" added into lookup table: "Nikon"
New lens exif id/value info: "66 40 2D 44 2C 34 6C 02" | "Nikkor 18-35mm f/3.5-4.5D IF-ED AF Zoom" added into lookup table: "Nikon"
New lens exif id/value info: "LUMIX G VARIO 12-35/F2.8" | "Lumix G Vario 12-35/f2.8" added into lookup table: "Panasonic"
New lens exif id/value info: "4 231" | "smc PENTAX-DA 18-250mm f/3.5-6.3 ED AL [IF]" added into lookup table: "Pentax"
LensDB - Loading lens entries from "/opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/lens-db.xml" | Cameras found: 0 and updated: 0 | Lens found: 1209 and updated: 1209
/home/robin/.AfterShot Pro 3/bibbledebug
Creating main window
Starting Catalog Manager
////////////////////////////////at this point the Corel crash screen comes up as it encounters the error/////////////////////////////////////////
Click Resume
New Io Asset Mananager
DB 0 at version 20
Locking catalog: "/home/robin/.AfterShot Pro 3/cache"
Locking for station: "{90316eab-8944-4624-9add-ea5678c21fd0}"
"/home/robin/.AfterShot Pro 3/cache/aftershot.lock" Previous lock: "{90316eab-8944-4624-9add-ea5678c21fd0}"
Opening DB "/home/robin/.AfterShot Pro 3/cache"
DB 1 is already up to date
Scheduled Cache Cleaning
CacheReducer removed 0 versions due to age older than QDateTime("2016-07-12 09:30:11.769 BST Qt::LocalTime")
Starting cache cleanup
Finished cache cleanup
Locking catalog: "/home/robin/Pictures/AfterShot Pro Catalog 3/AfterShot Catalog 2016"
"/home/robin/Pictures/AfterShot Pro Catalog 3/AfterShot Catalog 2016/aftershot.lock" Previous lock: "{90316eab-8944-4624-9add-ea5678c21fd0}"
Opening DB "/home/robin/Pictures/AfterShot Pro Catalog 3/AfterShot Catalog 2016"
DB 2 is already up to date
Starting Asset Manager
Starting Memory Manager
Trying to set copyset shortcut "Ctrl+8" for "Color Correction"
Trying to set copyset shortcut "Ctrl+9" for "Exposure"
Trying to set copyset shortcut "Ctrl+3" for "GPS Settings"
Trying to set copyset shortcut "Ctrl+4" for "IPTC Photographer's Details"
Trying to set copyset shortcut "Ctrl+1" for "Metadata and IPTC"
Trying to set copyset shortcut "Ctrl+2" for "Metadata, IPTC, and GPS"
Registering AfterShot plugin... "BibbleBuiltin"
Registering AfterShot plugin... "Equalizer"
Registering AfterShot plugin... "BlackAndWhite"
0 : "UncompressedRawData"
1 : "RawNoise"
2 : "Demosaic"
3 : "TiffSrc"
4 : "JpegSrc"
5 : "Mip"
6 : "PreScalingFilter"
7 : "CameraRgbToWorkingspace_Rendered"
8 : "CloneLayer"
9 : "HealingCloneLayer"
10 : "HealRendererFilter"
11 : "Highlights"
12 : "SpatialDistortion"
13 : "Positive Vignette"
14 : "Mirror"
15 : "Crop"
16 : "WhiteBalance"
17 : "AutoLevel"
18 : "Exposure"
19 : "FillLight"
20 : "USM"
21 : "CameraRgbToWorkingspace_Raw"
22 : "PerfectlyClear"
23 : "Sharpen"
24 : "Invert"
25 : "Color"
26 : "SelectiveColor"
27 : "EqualizerFilter"
28 : "RgbToLab"
29 : "LabToRgb"
30 : "BlackAndWhiteFilter"
31 : "Curves"
32 : "Negative Vignette"
33 : "WorkingToMonitor"
34 : "AthentechPFCNoise"
35 : "RedeyeBuf"
36 : "Redeye"
37 : "Watermark"
0 : "VersionStackSrc"
1 : "PostImage"
2 : "AthentechPFCNoise"
3 : "RedeyeBuf"
4 : "Redeye"
5 : "Watermark"
0 : "JpegSrc"
1 : "Mip"
2 : "WorkingToMonitor"
"/opt/AfterShot3(64-bit)/supportfiles/tools//"
Ready
QSslSocket: cannot resolve SSLv2_client_method
QSslSocket: cannot resolve SSLv2_server_method
QObject::connect: No such signal QAction::trigger(bool)
QObject::connect: (receiver name: 'Directory View')
Initializing file system view...
File: s: 28
File system view initialized.
Container __CATALOG_ROOT__/assets
No custom slideshow settings found
MultiImageView::doCursor() Invalid cursor mode
File: s: 6
File: s: 12
File: s: 44
File: s: 3
File: s: 10
ContainerAsset could not get path by ID
Container __CATALOG_ROOT__/assets/home
Container __CATALOG_ROOT__/assets/home/robin
Container __CATALOG_ROOT__/assets/home/robin/Pictures
Container __CATALOG_ROOT__/assets/home/robin/Pictures/Pentax
set sort order ascending
Container __CATALOG_ROOT__/assets/home/robin/Pictures/Pentax/2016
viewmode: 1
Starting import with settings : "<x:xmpmeta xmlns:x="adobe:ns:meta/" x:xmptk="XMP Core 4.4.0">
<rdf:RDF xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#">
<rdf:Description rdf:about=""
xmlns:bibp="http://www.bibblelabs.com/BibblePrivate/5.0/"
bibp:MoveCopy="2"
bibp:LibraryLoc=""
bibp:LibraryID="1049"
bibp:LibraryUuid="{8b53dd68-fd9d-4575-99e9-812286d2861c}"
bibp:Organize="0"
bibp:FolderTemplate=""
bibp:Recurse="false"
bibp:RenameOn="false"
bibp:FileTemplate=""
bibp:ImportPath="/home/robin/Pictures/Pentax/2016"
bibp:KeywordList=""
bibp:FolderFilter=""
bibp:QueueName=""
bibp:QueueType="0"
bibp:QueueOnlyNewFiles="false"
bibp:JobName=""
bibp:PresetList=""/>
</rdf:RDF>
</x:xmpmeta>
Adding master versions
Scanning file "/home/robin/Pictures/Pentax/2016/IMGP2166.jpg"
Importing: "/home/robin/Pictures/Pentax/2016/IMGP2166.jpg"
TIFF Error: /home/robin/Pictures/Pentax/2016/IMGP2166.jpg "Not a TIFF file, bad magic number 55551 (0xd8ff)"
defaults: "DefaultRendered.xmp"
Segmentation fault
robin@mopsie:~$
Can't seem to find a way round this - this/these are fresh PEF's edited and saved in ASP3
This has happened on 2 different machines - both with 'buntu 14.04 LTS base - different DE.
tm42
System_Drive: N/A
Re: ASP3 linux - bad magic on opening jpgs
Post by tm42 »
My "Solution":
AS3 crashed , reading JPEG Files. But only Files edited with ImagMagick.
I used ImageMagick Convert to resize images.
After i used GraphicsMagic - a ImageMagick Fork - there are no more Problems.
I think, there are some Linux Apps using Imagemagick Libraries, so there are more possible Problems...
Tested with Linux Mint 17.3 and 18 - based on Ubuntu 16.4 and 18.4
tony_redink2000
System_Drive: N/A
Post by tony_redink2000 »
I found clearing the exif information allowed AFP3 to read the images again!
To clear all I did:
bin
Post by bin »
Well, as of yesterday this defect remains unfixed with no fix date available.
As far as I am concerned this software is not fit for purpose.
If I cannot even browse an extensive range of pics in RAW and JPG format without the thing crashing it is not a viable product.
I requested a refund via Cleverbridge - so far no reply but there we are.
ganthore
motherboard: MSI Z87-GD65
processor: Intel i7-4770 3.40GHz
Video Card: Nvidia GeForce GTX 980
sound_card: Intel HD Audio
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Asus ProArt
Corel programs: After Shot Pro 3
Post by ganthore »
I upgraded to 3.1.0.181 and can't seem to see photos on my Gentoo system (JPGs and Olympus RAW ORFs). My process of installation involves unpacking the RPM to / on the file system.
Prior versions, this wasn't an issue... The log file indicates that the application can "scan" for files, but the editor UI will not render them for some reason (see attached screen shot).
Code: Select all
2.259: Scanning file  "/home/ganthore/Pictures/photography/P9090104.ORF"
I also noticed that fuji camera profiles don't even exist in the current RPM bundle. I double checked just to be sure. The log is throwing this error during initialization:
Code: Select all
0.216: Couldn't open lens table file: /opt/AfterShot3(64-bit)/supportfiles/Profiles/LensProfiles/profile_fujifilmlenstable.txt
