How to edit/reselect an effect?
theTastyCat
Post by theTastyCat »
Hey all - first post! I've got PSP X8, and I've created a nice graduated filter effect, but I'd like to lighten it up some. Trouble is I can't for the life of me figure out how to reselect it so I can edit it! I really don't want to have to undo all the way back to un-creating it since I've put work in since then. I'm sure this is easy...would be most grateful for your wisdom!
Many thanks!
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: How to edit/reselect an effect?
Post by Forriner »
Until an expert answers, maybe this:
If I misunderstood, please disregard, but if you open the History palette (menu View/Palettes/History -or- F3) and Ctrl-click on the single step you want to undo, it will work if the step wasn't non-undoable/dependent on other steps. You may need to Ctrl-click to select the action's bar first, before clicking the undo box.
You can't, as far as I know, open that step to re-do it with different parameters. You can perform the step again but it will go to the top of the stack.
Consider working with (adjustment) layers which you can readjust (if it's an adjustment layer), move around the stack, delete etc.
theTastyCat
Forriner, thank you so much - I had no idea the History palette existed!! Will try as soon as I get home. And you're absolutely right - this should have been its own layer.
I've only had PSP for three days, but my photos have absolutely come to life. Truly amazing software!!!! And I can afford it - imagine that!
Kathy_9
Hard_Drive_Capacity: 2TB
Post by Kathy_9 »
If your graduated filter effect is on it's own layer you can select that layer in the layer's palette and lighten it.
theTastyCat
Yeah, like a noob I didn't put it in its own layer - wont' make that mistake again!!
