Uninstalling/Reinstalling VS9 can be tricky
chinito
Post by chinito »
Didn't see this posted anywhere and thought it might help folks trying to re-install VS9. Had a problem with VS9 (upgrade) and tried uninstalling/reinstalling VS9. VS9 would then try to startup and then just go away. Anyway, should you need to uninstall/reinstall VS9, here's how an email from Ulead recommends uninstalling (there's a lot of nooks & crannies that need cleaning out):
1) Clean up C:\Windows\temp directory. Clean up all files in C:\Documents and
Settings\[UserName]\Local Settings\Temp folder. Uninstall VideoStudio 9 from
control panel Add/Remove programs.
Delete following folders
=>C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead
VideoStudio
=>C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
=>C:\Documents and Settings\[Username]\My Documents\Ulead VideoStudio
=>C:\Program Files\Common Files\Ulead Systems\
Proceed to step 2, even if you can't complete step 1.
2) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
C:\Program Files\InstallShield Installation Information (Please set "Show hidden
files and folders." in folder option in OS)
3) Please del the folder " Ulead VideoStudio 9.0" folder in C:\program
files\ulead system
4) Run Regedit from Start/Run in Windows task bar
5) Delete folder {88F92798-59AB-474F-B40D-1EC5F782F7EE} in
KEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\
(If you always see Ulead VideoStudio 9 file name showed in the Add/Remove
Program, please do point 5)
6) Then reinstall UVS 9 again
Hey, what do I know - it worked....
chinito
Oops, System Info
Post by chinito »
Forgot to mention:
XPHome SP2
Athalon 3200 512MB
200GB HD
Of course, your mileage may vary. Cheers!
