Need Microsoft KB update numbers for CVS X5 and X2
awbarnett
- motherboard: AMD Gigabyte 990FXA-UD3
- processor: AMD FX 8350 8 core 4.0 GHz
- ram: 16 GB
- Video Card: NVIDIA GeForce GTX 660
- Monitor/Display Make & Model: Samsungt SyncMaster NVIDIA GeForce GTX 660
- Corel programs: PSPX2, VSX2, VSX5, VSx6, VSX9
I need a complete list of Microsoft KB updates that stop older CVS programs such as CVS X5 and X2 from running. Due to HD crash I no longer have my list.
I would appreciate the KB numbers very much.
Thank you, Anthony
Thank you, Anthony
awbarnett
- ram: 16 GB
Re: Need Microsoft KB update numbers for CVS X5 and X2
Thanks for the reply Brian. Unfortunately it doesn't answer my question.
Well it says
what do you want to know if not that ?For those who do not wish to take up that offer earlier versions can be run by uninstalling the Windows Updates, hiding the updates to stop them installing again, this is of course at your own discretion and may affect pc security?
How…
In Control Panel, Programs and Features, click View Installed Updates. Top left
- Remove KB3126587 and/or KB3126593
In addition KB3140410 may also be causing some issues reported for X6 and X5
- Do NOT reboot.
Now go to
Control Panel - Windows Updates
Run Check for Updates, it should find the two updates
View updates to install
Select update , right click
Hide updates KB3126587 and/or KB3126593 and KB3140410
awbarnett
- ram: 16 GB
That lists only 3 KB's. There have been about 8 or 9 KB's all together. I was hoping that someone may have a list of ALL of the related KB's.
Replace this file in ..........
C:\Program Files (x86)\Corel\Corel VideoStudio Pro X5
awbarnett
- ram: 16 GB
Hello Lata
Thanks for your reply. I appreciate your interest.
I do not have a file "MUIHelper.dll" in the "C:\Program Files (x86)\Corel\Corel VideoStudio Pro X5" directory. Is the path you gave me complete?
Also, exactly what does the MUIHelper.dll do? Can you explain to me?
Thanks, Anthony
Thanks, Anthony
Yes the address C:\Program Files (x86)\Corel\Corel VideoStudio Pro X5 is correct assuming you installed the program to the default location?
Do a search for MUIHelper.dll
the new file will allow X5 to run irrespective of Windows update.
and probably work for X2
You can then set Windows Updates to auto.
awbarnett
- ram: 16 GB
Hello Lata
My Hats off to you! The DLL file you sent seems to correct the problem that the KB Update files make and cause CVS X5 to stop working.
After (first changing the name of the original MUIHelper.dll - for backup) I copied the MUIHelper.dll you sent to me into the directory.
Then I downloaded and installed the first 3 KB files (as shown in the above post). CVS X5 seems to work OK. At least it loaded OK.
I can't actually test CSV X5 with a project at the moment, but hopefully, I can do it in the near future.
I'm curious to learn where you got the new DLL file. It was my understanding that Corel was not going to give us a fix for the older versions of CVS.
Your help is very much appreciated. Thank you, Anthony
Corel provided a Hotfix for X8 and x7 those fixes provided a new MUIHelper.exe, did not take to long before someone tried those files in earlier versionsawbarnett wrote:Hello Lata
It was another user on the forum reported being able to do that, cannot remember her name?
Post updated
This post refers, thanks to Dawn
http://forum.corel.com/EN/viewtopic.php ... 31#p324607
awbarnett
- ram: 16 GB
Hello Lata
Thanks for sharing the information regarding Corel's fix for the newer CVS versions and that someone experimented with the subject DLL file for earlier CVS versions.
I appreciate your help. Thank you, Anthony
