I am using MSP 7.20 to capture and create DVDS using Ulead disc creator 3.0. I shoot local high school soccer games and am outputing to DVD. Each half is approximantly 40 minutes in length. I do not have to edit the footage at all just simply put on DVD with titled menu.
I am captureing using MSP 7.20 capture and the Ulead Direct show capture plug in. My captured AVI files have the settings below when captured.
24 Bit 720x480 4:3
29 fps
comp rate 6%
PCM 4800 KHZ, 16 bit stereo audio
In previous experience I have found that loading the AVI files into disc creator 3.0 with the project setting below and allowing it to do the MPEG conversion yeilds the best quality (as apposed to allowing video editor creat the MPEG file).
MPEG files
24 Bits, 720 x 480, 29.97 fps
(DVD-NTSC), 4:3
Video data rate: Variable (Max. 4000 kbps)
LPCM Audio, 48 KHz, Stereo
However the AVI files of these games are exceding the 4.38 GB DVD limit. any suggestions on how I could compress my AVI files ( as little as possible) when capturing using MSP 7.0 would be helpful, or any suggestion on the path I should take for an 80 minute DVD.
BPVIDEO
Capturing 30-40 minute clips for DVD output
Intel D865GBFL Motherboard
Intel 2.8 Ghz P4 w/800 Mhz FSB
1 GB DDR PC3200 RAM
40 GB Western Digital HD
80 GB Western Digital HD
128 MB MSI ATI 9200se w/ TV out
Adeptec AFW-4300 3 port firewire
Sony DWU18A DVD- RW +/- RW
Sony VX2000, Canon Elura A
1 GB DDR PC3200 RAM
The size of the AVI files is not in the least material: it is the size of the mpg files that counts.
I suggest you use DD AC-3 audio at a low bitrate (say 128 kbit/s) to gain a lot of space. For 2 hours of video, you should have no difficulty fitting it in with 4000 kbit/s max, unless you have horrendously large menus.
I suggest you upgrade to MF4: with this you can capture and encode with a better quality than MSP7.2, without having to switch apps. If you keep with MSP, then upgrade to 7.3 with the free SP3.
heinz-oz
Sorry, Heinz, you are upside down in Oz
: NTSC has AC-3 2/0 as its standard.
Sorry that was a typo. Suppose to be 30-40 minute clips( I edited the original post and corrected).
I will try changing the audio settings tonight and see if that will fix the problem, ( I knew I was missing the boat on something), thing that seems odd to me was even if I went with a lower quality setting (lower bitrate) it does not change the project size in indicator it still shows the file is to large over 4.7 gigs.
Thanks for the upgrade info Devil somehow I missed that one! I think I will hold off on the MF4, awaiting MSP 8.0 to see what Ulead may offer with that.
BPVIDEO
BPVIDEO
1 GB DDR PC3200 RAM
1 GB DDR PC3200 RAM
Thanks to everyone, changing to the DD AC-3 did the trick was able to raise the bitrate to 6000 kbs which is what I have found to work well with my football games.
BPVIDEO
BPVIDEO
1 GB DDR PC3200 RAM
1 GB DDR PC3200 RAM
