VSX9.5--Changing Duration Time on Multiple Photos at Once
Old_Friend
motherboard: HP Compaq 6200 Pro
processor: Intel Core i3-2100
ram: 4GB
Video Card: Intel Onboard
sound_card: Intel Onboard
Hard_Drive_Capacity: 500GB
Corel programs: VS Ultimate X5, VS Ultimate X9
Post by Old_Friend »
Hi. Although I've looked and tried numerous ways to do this, maybe I'm missing something? To me, it seems like a logical thing to have in the editor but, I am at a loss why it isn't available. I have a number of photos (jpg images) which I've placed into the timeline (top track) so that I can make a movie that appears as a slide show. Please, see the attached image which explains the issue. Any help will be appreciated.
How to change duration time on multiple photos simultaneously
HP Compaq 6200 Pro SFF PC, MS Windows 10 Home, 4 GB's RAM, Internal GPU and Sound, Browser: Firefox v. 74.0(64-bit), VS v.X9
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: VSX9.5--Changing Duration Time on Multiple Photos at Onc
Post by asik1 »
Have you actually selected them?
Panasonic X900m, VXF1
Post by BrianCee »
put all the still images in the timeline - select the first and hold down SHIFT as you select the last (standard windows procedure)
RIGHT click on the selected block and choose "change photo duration" from the pop-up - a small clock will appear - whatever you set there will be the duration of each photo (clock is "Hours - Minutes - Seconds - frames")
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
You can also grab the end of the clip and with "Shift" pressed drag to where you want it to end. That gives good visual control.
However, that only works on a per clip basis.
Old_Friend
ram: 4GB
Thanks for replying.
The answer to each of you is "Of course, I selected a group of the jpgs (all on the same track) prior to trying to find some way to change the duration of all of them at once to some number of seconds. Each one was supposed to have the SAME number of seconds duration." When more than one of them is selected (highlighted), the Photo Duration option turns OFF. That's the only reason I wrote and asked for help.
Old_Friend
ram: 4GB
asik1 wrote:Have you actually selected them?
You put MOVIES in your timeline. I put jpg images in my timeline, as I stated in my first post.
EDITED: Well, I don't know why this happened but, suddenly it began working? I had spent at least an hour or more trying everything and it wasn't working no matter what I tried. Gee whiz. So, my entire post can be deleted.
