NO(!!) Sony RX 100 distortion values in lens-db.xml
Bugs & Suggestions
buntu
operating_system: Linux
System_Drive: N/A
motherboard: Asrock
processor: X270
Video Card: GF210
sound_card: SBx00 Azalia
Hard_Drive_Capacity: 5GB
Monitor/Display Make & Model: Viewsonic, HP
Post by buntu »
I am very disappointed with Aftershot Pro 3, there are still no distortion values in lens-db.xml for the old Sony RX-100. The RX-100 is now on the market for years. ASP3 recognizes the camera, but doesn't do any correction and this small camera has, because of the size, a lot of distortion when RAW is used.
Corel, why do you enter lenses / cameras with no values? There are empty values since ASP1 for the RX 100.
I know, that it can be adjusted manually, but I have no idea, if there are better values than I used till now with ASP1:
cal_abc: 10.4 0.00836 -0.05316 -0.02788
cal_abc: 12.8 0.00891 -0.06095 0.02196
cal_abc: 14.9 -0.00571 0.00909 -0.06449
cal_abc: 16.6 -0.00428 -0.01113 0.0042
cal_abc: 19.1 0.00523 -0.03743 0.03369
cal_abc: 20.4 -0.00312 -0.00368 -0.0036
cal_abc: 23.3 -0.00222 -0.00843 0.01379
cal_abc: 25 -0.00565 0.0037 0.00318
cal_abc: 26.9 -0.00245 -0.00859 0.01924
cal_abc: 28.8 -0.00842 0.0158 -0.01114
cal_abc: 33.2 -0.01065 0.02132 -0.01154
cal_abc: 37.1 0.00226 -0.02401 0.0397
The format with ASP3 has changed too. It looks now like "<RadialDistortion a="0.003091" b="-0.022634" c="0" focal="6"/>"
I use Aftershot with http://xubuntu.org/
thermoman
System_Drive: N/A
Re: NO(!!) Sony RX 100 distortion values in lens-db.xml
Post by thermoman »
I have patched my lens-db.xml for Lens distortion on the Sony DSC-RX 100 and can give you the data needed in a couple of hours when I'm back home.
