HI All, i've been using corel VS X5 pro and now i'm using X9 ultimate
i was able to create the videos in custom menu with any data rate i want (depending on the video quality) in X5
NOW EVERY TIME i try to create A video. the output is always 2700 KBPS, however i adjust the setting it keeps created with this quality,
the original video is 1280*720 8000 KBPS 29 FPS, i edited it and saved it with the same settings in MP4, it has to be 1.64 gb
but the output file is always between 2400 & 2700 KBPS 460 Mb. which is a very bad quality compared to the original
PLZ HELP
how to create HD Quality mp4 Edited Video
- aljimenez
- motherboard: Dell Inc. A08 4.16.2014
- processor: IntelCore i7-4790 3.60GHz 4Cores 8 Logical Proc
- ram: 24GB
- sound_card: AMD High Definition Audio
- Hard_Drive_Capacity: 500SSD+2TB
- Monitor/Display Make & Model: Three monitors, all Dell brand, one 4K
- Corel programs: Visual Studio, Paintshop
Re: how to create HD Quality mp4 Edited Video
Is that a typo that your input source is 29FPS? I'm going to assume so, and that you mean original source is 30fps.
To help you, I would need much more details. Like what is the format of the source video? Which camera is producing it? Use Mediainfo or Properties to provide format: example, is it mp4? mpg?
Then do you mean that even though you are specifying higher bit rates, the resulting rendered file has lower bit rates than you expect? The bottom line is that you are getting rendered files that are not as high a quality as you want. After knowing more about your issue, I'll perhaps be able to offer better suggestions, but right now, I recommend you render the same format as the original video source to avoid any conversion.
User for more than 10 years.
If, as we suspect, your original video is mp4, then make sure that in the VS Preferences > General the box beside "Show message when inserting first video clip into the timeline" is ticked. Then start a New Project. Drag one of your clips into the timeline. You should get a message asking if you want the Project Properties to match those of the clip. Say OK to that.
After editing your project, you then go to Share and select the option at the very top: "Same As Project Settings" (tick the box to the left of that). Give the new file a name and press Start. The resulting video should have exactly the same Properties as the first clip you inserted.
Note that "Show message" only works with the first clip in a New Project.
First of all Thank u Mr. aljimenez, and Mr. Ken Berry for ur qreply and ur help
For Mr. aljimenez: these are the Media info data:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 1.83 GiB
Duration : 31mn 6s
Overall bit rate : 8 424 Kbps
Writing application : Lavf55.1.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 31mn 2s
Bit rate : 8 000 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.290
Stream size : 1.73 GiB (94%)
Writing library : x264 core 130 r2274 c832fe9
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=36 / lookahead_threads=5 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=60 / keyint_min=6 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=8000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Tagged date : UTC 2015-05-22 00:09:53
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 31mn 6s
Duration_LastFrame : 4s 87ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 28.4 MiB (2%)
and yes after editing and even though specifying the same bit rates in custom mode or mp4 profile , the resulting rendered file has lower bit rates than i expect.
Mr. Ken Berry:
Thanks for help .... i have done the steps, and i got the exact bit rate as original but only with "enable smart render" is ticked on, without it its poor like before,
anyhow the video is played for 5 sec and then it turns into GRAY SCREEN ......OMG
Format : MPEG-4
Codec ID : isom
Duration : 31mn 6s
Video
Format : AVC
Codec ID : avc1
Duration : 31mn 2s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 31mn 6s
Bit rate : 128 Kbps
Mr. Ken Berry:
- aljimenez
- ram: 24GB
No idea how to help you yet. Explain what editing you are doing. Perhaps a short experiment: add video to time line and do no editing, then Share/render same as project (like Ken posted), report if quality is now the same.
