File maybe right protected.
pepegota
- motherboard: ASUS TUF Z390-Plus
- processor: Intel i9 - 9900k
- ram: 64 GB
- Video Card: GTX 1660 6GB
- sound_card: On board sound
- Hard_Drive_Capacity: 2 TB
- Monitor/Display Make & Model: Ben Q, "21" LCD
- Corel programs: VS 2018, VS 2019, VS 2020
I copied from my Panny TM 900 recorder and processed the results in VS X9. When I went to "Share,' to process the file, a message came up. See attachment. I tried the same chip in my other two computers and there was no problem-no error message so, the chip is ruled out. I noticed the the BDMV folder was write-protected, but so was it in the two computers that worked. Why is VS seeing the files as write-protected? This never happened with VS before. I tried using the Panny USB, but it said write-protected. Yet, no problem on two other machines.
pepegota
- ram: 64 GB
Re: File maybe right protected.
Solved the problem. I changed directory and it worked. Then I changed back to original directory and it worked too!!
That error message shows if you try to save to a folder that does not exist. Could be USB memory that has been removed?
You may have saved to say BDMV folder then deleted that folder, trying to Share again will look for the same folder, that does not exist.
Choosing another Save location will fix the issue.
Its the wording of the error message that does not make sense
