Keyboard shortcut for X8
I know that Undo is Crtl + Z. Is there a Redo keyboard shortcut?
Forriner
- motherboard: ASUS Z170M-PLUS
- processor: Intel Core i5-6400
- ram: 16 GB
- Hard_Drive_Capacity: 1250 GB
- Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
- Corel programs: PSP 2023
Re: Keyboard shortcut for X8
Hi grinolot,
If you open the Customize dialog box (menu View/Customize...) and click on the Keyboard tab, you can see, set and change keyboard shortcuts.
For example, redo is an option on the Edit menu, so in the Category dropdown box, click Edit.
Under Commands scroll down to Redo.
In the Current Keys box you see that Ctrl+Alt+Z = redo, as well as Shift+Alt+Backspace. You can click on one of those and click the Remove button to remove a shortcut.
You can key in a new shortcut in the box below and click the Assign button. If your combination is already assigned to something else, that will be displayed under the box.
You can also view shortcuts under menu Help/Keyboard map...
Thank you very much Forriner!
Is there an option to put the straighten tool on my personalized toolbar. I looked and didn't find that option.
Forriner
- ram: 16 GB
Sure there is.
Open Customize and your toolbar.
On the normal PSP toolbar find the the straighten tool, and hold down the Ctrl key while you drag the straighten tool to your own toolbar. You should see a little + sign as you drag, because you're copying it with Ctrl. Without Ctrl you'd move it from the original position, which you probably don't want to do.
Edit: By the way, the straighten tool should be in the Customize dialog, under the Category 'tools'.
Awesome! Thank you!
