VS X9 Time Line Problem
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Re: VS X9 Time Line Problem
Post by asik1 »
If you just want to get this project done and over with, reedit your MCE segment correctly and than reimport it and don't touche it any longer.
Panasonic X900m, VXF1
Hi Mark
The MCE is sync' tool which also allows us to choose camera angles, it is not a Multi Trim tool.
I suspect it may be the project portion rather than the clip that is affected by MCE, if so you could try moving all clips to the library creating a copy.
Then delete clips from the timeline and replace with library copies, that of course will remove any transitions.
You may have to use Ctrl + drag and Drop when replacing the clips.
Make a copy of your project to test this out, File Save As.
I will try this later, when i have time..
Hi Mark
So far I am unable to remove the MCE edit effect applied to the project but can change individual clip length by using the library or Overlay track
1 / drag a clip to the library.
2 / use the trim bar below the preview screen to remove / add frames
3 / delete clip from timeline and replace with clip from library.
Or
Drag clip to overlay track to trim ends
Drag edited clip back to top timeline
Bingo
Do you have earlier versions of video Studio X8 or X7
Save the project again File – Save As
Save as type for X8 or X7
File new project to close existing project
File Open Project to open new project
Now MCE effect on project seems to have been removed allowing you to edit normally.
If you do not have X8 or X7
Zip your vsp and attach to your post, I will do the save and send back to you.
mark9422
motherboard: ASUS P8Z68 DELUXE GEN3 LGA 1155
processor: Intel Core i7-2600K Sandy Bridge 3.4GHz OC to 4.5
Video Card: PNY GeForce GTX 560 Ti
sound_card: Realtek HD Audio
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Asus HDCP 24"
Post by mark9422 »
I like your last suggestion! Last version I have is VS6 Pro.
So...I will send you my project file. And have you save as VS 7 or 8 project file.
Should I post it here or email to you?
And a million thanks!!!
Mark
Hi Mark
Zip the vsp and attach to this post.
I will not be able to view the content as i do not have your files, but will be able to save it for X8 and send it back.
You will be able to open in X9 and hopefully trim those clips.
there is always something new to learn.
mark9422
Post by mark9422 »
Attached is my project file for you to save as VS 7 or VS 8 and return to me.
Thank you!!
2016 Family Movie.zip
(66.6 KiB) Downloaded 114 times
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Try this, saved as VSX8
2016 Family Movie VSX8.zip
(34.14 KiB) Downloaded 128 times
Thanks Robert, you are up a little earlier than me :wink:
mark9422
Post by mark9422 »
Thanks guys! I'm just getting to work (5am here) I'll check it out later when I'm home and report back.
Sorry this is taking so long ..but good detective work always pays off!
Mark
Hi Mark
One thing I noticed….
You referred to Bluray plugin in an earlier post.
I assume you would be burning a Bluray disc yet your project properties are set for SD 720 x 480.
I would have expected 1920 x 1080 especially as your video files indicate using MTS.
Personally I would set Project Properties to match my MTS files, then render to MTS settings to create an output file in High Deffinition
And if I need SD DVD convert that file to mpeg2?
mark9422
Post by mark9422 »
Sorry for the delay but life obligations have kept me from trying your file. I just havent had the time. I hope to be able to give it a whirl this weekend. Looking forward to it!
Thanks again for your patience.
Mark
Hi Mark
I did slip up a little in getting you to upload the VSP, in fact you could have done the "save to X8" option.
Don’t know why I thought X8 had to be installed.
File – Save As – give it a new name --- in the Save Type choose X8 – then Save.
Then File New to clear the timeline, then open saved VSP.
mark9422
Post by mark9422 »
ha ha ! I thought the same thing after I uploaded the file to you!
Great minds think alike!
Thanks!
mark9422
Post by mark9422 »
IT WORKED !!!! :D :D :D
Program time line is back to normal! You are a genius ! Now I can finally get caught up with my movie.
My biggest question is why did this happen in the first place? And should I be saving as VS8 from now on?
Cheers!
