PAL vs. PAL-M vs. NTSC
WestbrookNH
motherboard: Hewlett-Packard 1631 KBC Version 01.33
processor: 2.30 gigahertz Intel Core i7-2820QM quad w HT
ram: 8 GB
Video Card: NVIDIA Quadro 2000M
sound_card: NVIDIA High Definition Audio 4x
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: Generic PnP Monitor (15.7"vis)
Post by WestbrookNH »
I want to send a DVD to Brazil.
In Brazil, they use PAL-M, which, unlike other PAL formats, has the same frame rate and number of lines as NTSC, but formats the chroma information in PAL.
While MF2SE has a PAL burn option, it does not have a PAL-M option, or any other subset of PAL for that matter.
If I burn a DVD in PAL format, will it play in a PAL-M player?
Will an NTSC DVD play in a PAL-M player?
I have Movie Factory 2 SE (2.12.2166.0000 SE)
Thanks and regards
jcc
Post by jcc »
You can probably use NTSC as modern TV's in my PAL area also have an NTSC capability. Check with your Brazilian contact.
WestbrookNH
ram: 8 GB
Thanks, John.
I've been doing some surfing and I found these answers.
From http://www.shootfirst.co.uk/standards.htm
PAL-M is also 525 lines, with 60 fields per second (30 frames per second), but the colour burst signal is handled differently compared with NTSC. PAL-M is not compatible with PAL, but the black and white part of the signal is compatible with NTSC. Only Brazil and Laos use PAL-M so their consumer recorders often have the colour circuitry to play back both NTSC and PAL-M.
And from http://forum.ecoustics.com/bbs/messages/2/15350.html
HI.
I am from Brazil. 99.99999% of our TV´s are PAL/NTSC compatible. Our DVDs are recorded in NTSC format but with AREA 4 codification. Anything with a NTSC 60hz and 110 to 130V 60Hz compatibility will perform normally here.
So, it looks like I can send my NTSC encoded DVDs to my Brazilian friends and they can view them on their DVD players, as long as I set the region code on the DVD disk to 0 or 4 when I burn it.
