*.MOV with transparency problemm
ekkl
motherboard: Gigabyte
processor: Intel CoreDuo E7400 2.8GHz
ram: 4G 333MHz
Video Card: Geforce 512Mb
sound_card: internal
Hard_Drive_Capacity: 640Gb
Monitor/Display Make & Model: aseu 22"
Corel programs: VS MS
Post by ekkl »
If the to edit track place a * .mov file with transparency, editor hangs. Task Manager shows the zero load of this process, but the screen (editor window) does not respond to any mouse clicking. Menu does not work, I can't drag and drop a any track between tracks.
*.mov without transparency is placed without problems.
It works so in X8 and X9 versions.
Davidk
ram: 16Gb
Hard_Drive_Capacity: 6Tb
Re: *.MOV with transparency problemm
Post by Davidk »
More information please. Particularly, what you mean by a .mov file to the edit track with transparency . . .
The closest approximation I could come to this was
- a .mov video clip in the 1st overlay track, and a simple colour background in the main timeline.
- Size the overlay track image to fill the preview window (select the clip, grab the handles and drag).
- Select the video clip, and in the options panel choose advanced motion, and in the panel that opens, for the last/rightmost keyframe, choose opacity of 10%. click OK.
When played in project mode that gives a steadily fading image - transparency: you can see more of the background image as the play proceeds. And it works fine, VS functions as normal.
Davidk
Post by BrianCee »
if by ".mov with transparency" you mean a .mov with an alpa channel then unfortunately Videostudio does not support the alpha channel and as you have discovered will not play it
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
BrianCee wrote:if by ".mov with transparency" you mean a .mov with an alpa channel then unfortunately Videostudio does not support the alpha channel and as you have discovered will not play it
X9 does support QT+alpha.
If you don't have any to try, grab the globe from here
http://www.movietools.info/motion-eleme ... obe-2.html
you can also apply the NB drop shadow to it.
Panasonic X900m, VXF1
Hi Asik
I downloaded the Mov Jpeg2000 which imported to X9 ok.
I do need Quicktime installed otherwise I get a File Format Mismatch
Windows sees the file as an audio file not Mov video?
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
lata wrote:Hi Asik
It's elementary mate,
you search better than me and you can find the QT terror thread.
Some Mov and Mpeg4 require QuickTime, catch 22 I suppose.
But as far as I know the threat was with the QT Web Player not the QT codec.
