VS X9 Ultimate crashing!
Pete Waterman
processor: Intel Core i7 7700
ram: 12gb
Video Card: AMD Radeo R5 435
sound_card: Realtek alc888s-VD Audio
Hard_Drive_Capacity: 3 TB
Corel programs: Video Studio Ultimate 2019, 2021, 2023
Post by Pete Waterman »
Hi All
Can anyone give me the solution for VS X9 ultimate crashing when I try to enter text?
I click on the T (text icon)
That brings up the "double click here to add title"
when I double click I get the text box (marching ants)
I cannot Ctrl C (I think it is to paste text) please correct me if I'm wrong?
If I click on the Marching ants the text box disappears.
If I type the text in and try to move it's position VS X9 crashes!
I know that you believe you understand what you think I said,
but I'm not sure you realize that what you heard is not what I meant.
Re: VS X9 Ultimate crashing!
Post by BrianCee »
That's a bit strange - when I click the "Double click here to add a title" my 'ants' are not marching - just a stable dotted text box which grows as I type
"Ctrl+C" is for copying the text from another source - - - "Ctrl+V" pastes the text into the box
can you use any of the pre-made titles which are supplied with Videostudio - do they cause the programme to crash ?
have you installed Service Pack 3 for X9 - that seems to be causing a lot of users a lot of different problems - try removing SP3 (windows restore - or uninstall and reinstall without SP3)
Pete Waterman
ram: 12gb
Thanks Brian
Yes the ants are the lazy ones (cant be bothered to march) sorry!
I have installed sp3.
I've just tried the pre-made titles they seem OK.
I re-opened my project and its behaving fine now?
I don't understand why, but if it happens again I'll uninstall SP3 and try that!
Thanks again for the advice.
PartyOnJ
motherboard: PEGATRON CORPORATION Eureka3 1.02
processor: 2.67 gigahertz Intel Core 2 Quad Q8400
Video Card: AMD Radeon HD 5450 [Display adapter]
sound_card: AMD High Definition Audio Device
Hard_Drive_Capacity: 4 TB
Monitor/Display Make & Model: HP w2338h & LG W2252
Corel programs: VideoStudio X9;PaintshopPro X6
Post by PartyOnJ »
Try running the "Troubleshoot Compatability" on it. As in, right click on the Corel VideoStudio icon. In the popup menu, click on Troubleshoot Compatability. After it runs the Detecting Issues, click on Try recommended settings, then click on Test the program. It will open VS. Work with it and see how it goes.
Go back to the Program Compatibility Troubleshooter, click Next. If it worked, click Yes, save these settings for this program. If not, select No, try again using different settings. It may just fix your problem.
Good luck. It worked for me.
