PSPx8 - Is there a way to multiply an image across the image
Wraith_3
motherboard: Asus Z87 Sabertooth
processor: Intel Core i7 4770k
Video Card: EVGA GTX 780ti SC
sound_card: Soundblaster Z-series
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Hanns G HG281
Corel programs: Painshop Pro 2018 64bit
Post by Wraith_3 »
I'm trying to print some toy money for my niece's American Girl dolls. I scanned an image of the toy money and I wanted to fill an image with as many copies as will fit so she can cut them out. Is there some way to do this? I thought it was called "tiling", but apparently that is something different in PSP.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Re: PSPx8 - Is there a way to multiply an image across the i
Post by JoeB »
I'm not sure there's an automatic way to do it. However, first create your dollar bill at the correct print size (I don't know the size of that money, but lets say 3.75" x 1.5" as an example). Make sure it has a print resolutions of 200 pixels per inch (PPI) to get a decent output from your printer. Then create a second image at a size of 8.5 x 11" at 200 pixels per inch (PPI). Then put the dollar bill in focus and, from the Layer's palette, drag the dollar layer onto your white (or transparent) large image and duplicate it 7 times, giving you 8 copies of it that you can then drag into place.
Just as easy is to create the dollar as above, then go to File>Print Layout, select an 8.5 x 11" template, and just drag copies of the dollar bill from the left hand preview column into place on to the template. I'm not sure but maybe the Print Layout window defaults to an 8.5 x 11" template.
JoeB
Using PSP 2019 64bit
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
If you select multiple layers with the pick tool you can use the Distribute command to evenly distribute the layers across the document.
Video demonstration - https://drive.google.com/file/d/0B8FlFL ... ktRXM/view
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Post by LindaSue »
Or, have the dollar bill image open in the workspace as well as a blank image that will be your printed document. Choose the Flood Fill tool. In the Materials palette, choose Pattern. Then choose the dollar image from the drop-down list and flood fill the blank image with the dollar bills.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
Wraith_3
Post by Wraith_3 »
Thanks!!! I'll try those suggestions.
