JoeB wrote:I'm not sure why PSP does this when other programs (at least GIMP, which is the example you used) don't. I don't have GIMP but if I use Copy on a web image and open Photoshop I can't even find an option to let me paste it into Photoshop as a new image so it isn't a program that accepts Copy from a web page, although you can do so in PSP with the result you described.
However, I have never used Copy to get an image from a web page. If you right click the image and select Save Picture As... from the context menu it will save the picture in a folder of your choice and then when you open it in PSP it will have whatever transparency it had on the web page.
Thank you for your reply,
Yes, I don't think many people would do this very often (copying and pasting, instead of saving an image for use later); I was just working on some images and was in the 'flow' of copy/pasting some logos as various layers - and when PSP pasted in one from a webpage without Transparency, it was just ..."BOOM" no Transparency - and it made me stop and blink a few times... I don't think I regularly do it this way even, but I did a quick test with that other image editing application, just to see - and it came through, is all.
I'm not sure it is something that needs a "fix" or anything, I was just wondering if there was a setting somewhere that I was missing or a step I was skipping, as I am learning PaintShop Pro, in case this was something that normally happens a different way - thanks for letting me know your experience with it - I guess most people would just never run into this, heh.
Edit:
I remember why I wanted to mention this!
It also occurs when passing data between applications...
For example, if I take a Snapshot from Movie Studio (video editing program) and Paste it into PSP, it gets 'flattened' with a Black background. However, if I Paste the same data into (again, as an example) GIMP, it gets Pasted/Imported with full Transparent capability (Alpha Channel information maintained).
- Transparency from Video Editor lost when Pasting (white fringe/blurry area)
Interesting.
