ASP3 failing to load - strace output
Bugs & Suggestions
q5sys
operating_system: Linux
System_Drive: N/A
Post by q5sys »
When I look in the deb file I dont see the path /opt/AfterShot3(64-bit)/bin/platforms/ so I'm not really sure why it's searching there when it's already found the libqxcb.so in /opt/Aftershot3(64-bit)/lib/plugins/platforms/
Code: Select all
stat("/opt/AfterShot3(64-bit)/bin/qt.conf", {st_mode=S_IFREG|0664, st_size=99, ...}) = 0
stat("/opt/AfterShot3(64-bit)/lib/plugins", {st_mode=S_IFDIR|0775, st_size=139, ...}) = 0
lstat("/opt", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
lstat("/opt/AfterShot3(64-bit)", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
lstat("/opt/AfterShot3(64-bit)/lib", {st_mode=S_IFDIR|0755, st_size=2820, ...}) = 0
lstat("/opt/AfterShot3(64-bit)/lib/plugins", {st_mode=S_IFDIR|0775, st_size=139, ...}) = 0
lstat("/opt/AfterShot3(64-bit)/bin", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
stat("/opt/AfterShot3(64-bit)/lib/plugins/platforms/.", {st_mode=S_IFDIR|0775, st_size=33, ...}) = 0
open("/opt/AfterShot3(64-bit)/lib/plugins/platforms", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFDIR|0775, st_size=33, ...}) = 0
statfs("/opt/AfterShot3(64-bit)/lib/plugins/platforms/", {f_type=0x61756673, f_bsize=4096, f_blocks=249830, f_bfree=52278, f_bavail=48182, f_files=65536, f_ffree=49079, f_fsid={0, 0}, f_namelen=242, f_frsize=4096, f_flags=4128}) = 0
getdents(3, /* 3 entries */, 32768)     = 80
getdents(3, /* 0 entries */, 32768)     = 0
close(3)                                = 0
lstat("/opt/AfterShot3(64-bit)/lib/plugins/platforms", {st_mode=S_IFDIR|0775, st_size=33, ...}) = 0
lstat("/opt/AfterShot3(64-bit)/lib/plugins/platforms/libqxcb.so", {st_mode=S_IFREG|0775, st_size=1307432, ...}) = 0
open("/opt/AfterShot3(64-bit)/lib/plugins/platforms/libqxcb.so", O_RDONLY|O_CLOEXEC) = 3
fcntl(3, F_SETFD, FD_CLOEXEC)           = 0
fstat(3, {st_mode=S_IFREG|0775, st_size=1307432, ...}) = 0
mmap(NULL, 1307432, PROT_READ, MAP_SHARED, 3, 0) = 0x7f7c870e7000
close(3)                                = 0
munmap(0x7f7c870e7000, 1307432)         = 0
stat("/opt/AfterShot3(64-bit)/bin/platforms/.", 0x7ffd1ba68670) = -1 ENOENT (No such file or directory)
fstat(1, {st_mode=S_IFCHR|0620, st_rdev=makedev(136, 0), ...}) = 0
write(1, "Fatal: This application failed t"..., 105Fatal: This application failed to start because it could not find or load the Qt platform plugin "xcb".
) = 105
write(1, "Reinstalling the application may"..., 51Reinstalling the application may fix this problem.
) = 51
open("/dev/tty", O_RDONLY|O_CLOEXEC)    = 3
close(3)                                = 0
write(2, "This application failed to start"..., 149This application failed to start because it could not find or load the Qt platform plugin "xcb".
) = 149
rt_sigprocmask(SIG_UNBLOCK, [ABRT], NULL, 8) = 0
tgkill(9184, 9184, SIGABRT)             = 0
--- SIGABRT {si_signo=SIGABRT, si_code=SI_TKILL, si_pid=9184, si_uid=0} ---
+++ killed by SIGABRT +++
Aborted
