Video Studio X9 cannot initialise
Microsprint
Corel programs: corel Draw graphic suite x6
Post by Microsprint »
cannot initialize application no video I/0 plug-in DLL [16800:1:4] [15034:1:11] keeps giving me Load From Stream Error and can't close error message ...HELP !!!!
Re: Video Studio X9 cannot initialise
Post by BrianCee »
Use the task manager to close the error window by using "End Task" on the Videostudio.exe app
then un-install and reinstall videostudio X9
Microsprint
Then if I un install X9 I will lose all my stuff ?
Post by BrianCee »
No of course not - none of your "stuff" is actually in Videostudio - it is all just links
if you have set up some libraries which you want to keep you might like to export the library first and import it again when you reinstall - BUT if you don't do that you will still have all your "stuff" - you will just have to relink your libraries again
you might like to make sure any videos you have made are not in any of the Videostudio system folders - just in case
Microsprint
Load from stream error
Information
When launching VideoStudio Pro, a "Load From Stream"error will pop up on the screen, preventing the application from loading. This is due to corruption of the file library for VideoStudio Pro.
Resolution
1.Make sure that Corel® VideoStudio is closed
2.Open the Run command box (press and hold down the Windows and R buttons on the keyboard)
3.Type the following: appdata
4.Press the OK button
5.Open the Roaming Folder
6.Open the Ulead Systems folder
7.Rename the Corel VideoStudio Pro folder to Corel VideoStudio Pro_old
even after all this
I get this now
The funny thing is video studio x 9 works on my guest account .....go fig
The details there are a little old and refer to 32 bit programs.
You need to re-name this folder for your 64 bit program.
C:\Users\User Name\AppData\Roaming\Ulead Systems\Corel VideoStudio Pro (x64)
More details on resetting Video Studio, replace 18.0 with 19.0
http://lata.me.uk/corel/reset/reset.htm
