Keeping Ultimate Add-ons
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
I just want to point this out for folks who might not be aware of it.
As you know, a PSP Ultimate edition contains extras such as additional brushes and third-party software, and the particular add-ons vary from one PSP version to the next.
The add-on installers usually require that version of PSP to be installed, i.e., if you have X5, you upgrade to X7 and remove X5 and then you try to run an X5 add-on installer, it will tell you you need to install X5.
But once the installer is run, you normally can simply copy plug-ins, etc., to the new PSP version's plug-ins folder and they will work -- even if you have never had the older PSP version on that machine. So, for instance, you had an X5 Ultimate add-on installed on one machine and then you put X7 on a new machine. You can copy from the X5's plug-ins to the X7 machine and they usually will work. Similarly, you can copy brushes, etc., from one PSP version to another.
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: Keeping Ultimate Add-ons
Post by trueblue »
Each version of PSP creates its own sets of folders for your custom files. PSP also has its own folders and files on your system drive, which is usually C.
The custom files can be copied and moved elsewhere on your PC or to another hard drive, all you need to do is direct PSP via File Locations to those folders.
These folders also contain a Plugin folder where you can store/install plugins. It won't make any difference if you uninstall PSP and clear personal files as it will not affect those custom folders. It will however remove the current version number folders and all from PSP on your system C: drive.
I have plugins I have to install and these are never affected as they are in Programmes. However, upon installation of a new version I always have to do File Locations.
Many older 32bit plugins will only work in PSP 32bit. You have to have 64bit plugins for the 64bit version of PSP.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
