Parameter is out of Range error
wm59
- processor: AMD Athlon II X4 645 Processor 3.10 ghz
- ram: 8.00 gb
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Sony CPD-G220R
Hi I am running Windows 7 with Psp x7. I tried to use the curves command and I keep getting a error message : A parameter is out of range. I tried resetting the work space within PSP and it didn't work. So I next tried Shift clicking on the curves icon and it didn't help at all. I even try reloading the work space after resetting and still have the same problem. It was working about a month ago. Any suggestions.
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Parameter is out of Range error
You mentioned that you have reset the workspace but did you try to reset the Curves Tool itself? It's worth a shot.
wm59
- ram: 8.00 gb
I can't even get the curves box to come up to reset it. I just get a message box with a red X "A Parameter is Out of Range"
Kathy_9
In that case as a last resort I would uninstall using the clean-up tool found here http://forum.corel.com/EN/viewtopic.php?f=56&t=52337 and re-install.
wm59
- ram: 8.00 gb
Thanks for your help. I will give that a try.
This error was last reported here over five years ago so not common. But in that case resetting the program fixed it. Hold the Shift key down when you click on the PSP icon to open the program. You'll be asked if you want to reset it. Say yes. Make sure you have saved any customised workspace before doing all this. But at least it might avoid a full reinstallation.
wm59
- ram: 8.00 gb
I finally had to do uninstall and a re-install and everything works now. I really appreciate everybody's help.
Kathy_9
I'm glad you got it working again.
