I can't use the Screenrecording funktion
zoliapa
Post by zoliapa »
I just purchased VideoStudio X9.
The editor is working fine, but when I try to activate the screen-recorder I get this message.
Probléma-aláírás:
Problémaesemény neve: APPCRASH
Alkalmazásnév: VSSCap.exe
Alkalmazásverzió: 19.2.0.4
Alkalmazás időbélyegzője: 570e463e
Hiba – modul neve: StackHash_fccf
Hiba – modul verziója: 6.1.7601.23418
Hiba – modul időbélyegzője: 5708a857
Kivételkód: c0000374
Kivétel – eltolás: 00000000000bf262
Operációs rendszer verziója: 6.1.7601.2.1.0.256.1
Területibeállítás-azonosító: 1038
További információk 1: fccf
További információk 2: fccf9676fa686d9cee5471a607782dce
További információk 3: 95f5
További információk 4: 95f56460035b97b7d218c29003fd2534
Don't get confused, the notes are in Hungarian :-)
I downloaded the Hotfix package did not help either. I also checked all the Windows updates and deleted the ones that were recommended to be deleted.
Any idea what to try to get it to work?
Re: I can't use the Sreenrecording funktion
Post by BrianCee »
You do not need to delete or remove windows updates if you have installed the hotfix - - the hotfix was released to allow Videostudio to work with all windows updates installed - reinstate them they are security updates
you have given us the error report but not the error message itself - which would normally be something like "Failed to initiate capture" or something similar
what have you got in the window - many people have reported screen capture will not work if 5 channel surround sound is active
