ASP3 doesn't start anymore on Ubuntu 16.04 amd64
Bugs & Suggestions
JulienV
operating_system: Linux
System_Drive: B
Post by JulienV »
After updating from ASP2 to ASP3, I have quickly tested and everything was looking good (except the GUI was not translated into French any more but it is a different matter).
Today, I am not able to start ASP3.
Here is what I get when launching from terminal:
Code: Select all
% AfterShot3X64
Install Path:           /opt/AfterShot3(64-bit)
LD_PATH:                /opt/AfterShot3(64-bit)/lib:
XLIB_SKIP_ARGB_VISUALS:
I have SSE2
Bibble program arguments ("./AfterShot")
Linux does  not support Commond Folder. Uses  "/opt/AfterShot3(64-bit)/supportfiles"
Loading plugins
And then it gets stucked...
After removing "~/.Aftershot Pro 3" folder, I get the following output:
Code: Select all
% AfterShot3X64
I have SSE2
first run - setting up folders
I also see a window with "Choose Folder Locations" title, but do not see the contents of the window (it shows the contents of the window behind, and seems to be stalled as it doesn't close when hitting the x button.
I have tried downgrading QT related librairies, as well as compiz packages, with no success. I could not identify any other updates that could lead to this issue, but may have missed some.
I have no idea how I could try and debug this.
Any hint?
Cheers,
Julien
JulienV
System_Drive: B
Re: ASP3 doesn't start anymore on Ubuntu 16.04 amd64
Post by JulienV »
I have tried re-installing ASP2.4 and, though I am not able to open my catalogues (probably due to the fact I have opened them with ASP3), it starts fine.
Cheers,
Julien
eunix
motherboard: various
processor: various
ram: 15GB-32GB
Video Card: nvidia based GC
sound_card: onboard sound
Hard_Drive_Capacity: 160Gplus
Monitor/Display Make & Model: various
Corel programs: ASPro/Pro2/Pro3
Post by eunix »
I was able to run ASP 3 on Ubuntu machine that was upgraded to 16.04 however I am now having problems with it crashing.
I build out a new machine with a fresh install of 16.04 but I am unable to get either ASP 2 or 3 to start.
Is there a way to launch ASP with a command line switch that will output extensive information for trouble shooting?
eunix
processor: various
ram: 15GB-32GB
Post by eunix »
I attempted another fresh install on 16.04 .
This time one of my workstation class laptops.
the appliation did not start from the launcher so i tried to launch from the command line.
./AfterShot: error while loading shared libraries: libQt5Designer.so.5: cannot open shared object file: No such file or directory
bjornlinzer
System_Drive: N/A
motherboard: donotknow
processor: coreI7
ram: 12GB
Video Card: intel
sound_card: donotknow
Hard_Drive_Capacity: 512GB
Monitor/Display Make & Model: system76
Corel programs: ASP3
Post by bjornlinzer »
hi,
found the solution @
https://wiki.ubuntuusers.de/AfterShot_Pro/
sudo apt-get install libgstreamer-plugins-base0.10-0
after that, ASP just starts fine...
regards
björn :D
eunix
processor: various
ram: 15GB-32GB
Post by eunix »
Excellent! I can confirm that this works.
(1) I ran it on my laptop workstation which was a first attempt ASP install on 16.04 ( worked )
(2) I ran it on my fresh installed desktop buiild that I had backported in an attempt to follow the ASP error messages. (worked)
Note, I will have to do some clean up on this machine because I think I may have started going into left field
Thanks!
JulienV
System_Drive: B
Post by JulienV »
Sorry for the late reply, but I have been able to start ASP3 again after removing ~/.config/Corel/AfterShot Pro v3.conf.lock
I guess this flie was left there after a crash.
Cheers
Julien
eunix
processor: various
ram: 15GB-32GB
Post by eunix »
Even though I am able to launch the application now, there are stability issues and it crashes anytime I navigate to one of my picture folders to edit jpeg.
jamdo63
System_Drive: N/A
processor: Intel Core i7 CPU 870 2.93GHz x 8
Video Card: GeForce GTX 960 PCIe SSE2
Hard_Drive_Capacity: 1tb
Post by jamdo63 »
Using ASP3 on Ubuntu 16.04 and the app crashes reading many files / directories. I originally thought the crashes were with tif files but it is more complicated than this.
I have found some directories with only JPG files that cause the crash.
I have not yet found the common factor leading to the crashes.
