Opposite of the Cross Zoom Transition?
jezzer
motherboard: MSI Z170A PC Mate
processor: Intel Core i5-6600 3.30GHz
ram: 8GBx2
Video Card: Asus GeForce GTX 960 2GB
sound_card: Onboard Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: BenQ "24"
Corel programs: Videostudio X8.5
Post by jezzer »
Hi :)
Im using the Cross zoom transition perfect for what i want as no one used the zoom function on the camcorder,But i also need something where it zooms back out again on the next clip,Can this be done?
Re: Opposite of the Cross Zoom Transition?
Post by BrianCee »
Surely the cross zoom transition zooms in at the end of the first clip and back out again at the start of the second clip - isn't that what you want ???
for more complicated zooming have a look at "Customise Motion"
jezzer
ram: 8GBx2
Post by jezzer »
It doesn't look right if i add the cross zoom at the end of the clip as it doesn't zoom out.
Ill see if i can use Customise Motion.
Post by BrianCee »
clip 'A' zooms in - then clip 'B' zooms out - watch - - https://youtu.be/kYKYos7iBsM
jezzer
ram: 8GBx2
Post by jezzer »
Thats interesting because it doesn't look so smooth when ive been adding cross zoom,I did see in the options pannel its called cross zoom stretch is that what you have?
Post by BrianCee »
Yes I have the same one - what you see in the preview may not be accurate - render a short video with the transition in the middle of two clips and view the reult
jezzer
ram: 8GBx2
Post by jezzer »
Thanks Brian i made a short clip and it looked better thanks :D
