Please Help About Fade in/out
11suppakit
motherboard: MSI H110M PRO-VD
processor: INTEL 1151 CORE I7 6700
ram: 16 GB
Video Card: GALAX GTX 980ti HOF
Hard_Drive_Capacity: 1 TB
Corel programs: ilove Videostudio X8
Re: Please Help About Fade in/out
Post by 11suppakit »
lata wrote:Hi
I do not understand why this problem would cause you to abandon X9 and revert to X8 when X8 has the same issue.
I have done a few more tests and it appears the combination of the 3 crossfade transitions is the problem.
Removing the 12 second 16frame transition on the Overlay track covering SP-I01.jpg cures the problem. ( as Asik's image transition 1)
So clearly those three transitions combine together is the problem.
I gave you other options to create the same effect using Customise Motion which work as well if not better.
Windows 10 – I cannot help here but can only say that others on the forum run X8 on W10 without problems, it could also be a problem with your pc not X8?
GOOD NEWS !!
Now I can Install Videostudio X8 then i quickly to test the crossfade and It have no bug anymore AMAZING ilove X8
Thanks Iata
