Please Help About Fade in/out
11suppakit
motherboard: MSI H110M PRO-VD
processor: INTEL 1151 CORE I7 6700
ram: 16 GB
Video Card: GALAX GTX 980ti HOF
Hard_Drive_Capacity: 1 TB
Corel programs: ilove Videostudio X8
Re: Please Help About Fade in/out
Post by 11suppakit »
oh so sorry, yesterday that you ask me to attach file, i do not front of computer.
now i have upload it to you
Problem VSP file.rar
.VSP
(2.78 KiB) Downloaded 122 times
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
Downloaded your .vsp file, cannot see what your issue is, plays perfectly, transitions between the 2 titles maybe are a little too short, but overall can find nothing wrong
canuck
operating_system: Windows 8.1
Post by canuck »
The video from that vsp file looks perfectly good and I cannot see a problem with it. Then of course I don't really understand what you are trying to do. Also, that vsp fille is completely different from the 2 youTube videos you had uploaded.
Hi 11suppakit
Thanks for the vsp file, that has been useful as I did see the problem as a flash where the two text crossfades touch. I do not know what is causing that flash :?: :?:
There are many ways to apply effects and I have to say that I would not use a transition on the text but either Customise Motion or Text Animation.
I have modified the project to use those options rather than transitions, with your clips showing last.
“Text One” has had Text Animation applied, double click this clip to open Options panel., attributes tab.
All other clips have had Customise Motion applied, right click any clip for option.
Edited Problem VSP file.zip
this VSP will open using X8 and X9
(5.65 KiB) Downloaded 119 times
asik1
motherboard: H170M-E D3
processor: i5-6600
ram: 8gb
Video Card: GTX1050-2GB
Post by asik1 »
suppa, you have a valid point ! it's a bug.
The culprit is the third trans , no matter what trans.
This bug is on X7 also.
Looks as VS can scroll OK over that section but it can't play it right.
This can be replicate even with any PNG objects from library instead of the titles.
soon as there is a third trans, it will flash at a point.
Thank you for bringing it up.
What's kills me is, how come I never saw this and I'm sure I had 3 trans overlayed in the past... :oops:
Panasonic X900m, VXF1
Hi Asik
You probably never used two transitions and applied the one between two clips.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
lata wrote:Hi Asik
Well, 2 ovrelayed trans I do very often but over such hundreds I did, you think I never add 3rd? strange
Many times when I use many tracks the overlay comes with opacity settings not trans.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Actually there are 2 flashes
The first will be if the 2n'd overlay trans is more than 2 frames after the first trans started
(even if no 3rd trans at all)
The culprit is that trans 1 pauses at the last few frames of trans 2 but than jumps to its correct levels. once 2 ends
(I for sure never had 2'nd trans delay, I either advance it or in sync with 1)
** But... if you add a 3rd trans it will flash even if it just 2 frames ahead trans 1 ends.
I consider this a major bug.
Hi Asik
Sorry but I did check for a gap between the transitions and there is no gap, at least I do not see a gap.
but I do agree that it is a bug.
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
lata wrote:Hi Asik
What gap are you looking for and where? my screenshot isn't clear enough?
RobertOZ
Post by RobertOZ »
Well, your screen shot shows a gap between transition 2 & 3, the .vsp file provided by 11suppakit had no gap between those transitions, that is what I think lata is refering to
RobertOZ wrote:Well, your screen shot shows a gap between transition 2 & 3, the .vsp file provided by 11suppakit had no gap between those transitions, that is what I think lata is refering to
Exactly, thanks Robert
asik1
processor: i5-6600
ram: 8gb
Post by asik1 »
Oh... what I'm implying is that the gap between them has nothing to do with the flashes.
It's the overall position of 2 over 1 and if there is 3 at all in the game.
***for crossfading, the solution of corse is to use fades at the basic motion settings , or opacity in the advance.
But for all other trans its a bummer.
11suppakit
ram: 16 GB
Thanks a lot Lata and everyone, but i'm done with X9.
Now i really want to use X8 with my Windows 10 . Can you guys help me ?
I do not understand why this problem would cause you to abandon X9 and revert to X8 when X8 has the same issue.
I have done a few more tests and it appears the combination of the 3 crossfade transitions is the problem.
Removing the 12 second 16frame transition on the Overlay track covering SP-I01.jpg cures the problem. ( as Asik's image transition 1)
So clearly those three transitions combine together is the problem.
I gave you other options to create the same effect using Customise Motion which work as well if not better.
Windows 10 – I cannot help here but can only say that others on the forum run X8 on W10 without problems, it could also be a problem with your pc not X8?
