Please Help About Fade in/out
11suppakit
motherboard: MSI H110M PRO-VD
processor: INTEL 1151 CORE I7 6700
ram: 16 GB
Video Card: GALAX GTX 980ti HOF
Hard_Drive_Capacity: 1 TB
Corel programs: ilove Videostudio X8
Post by 11suppakit »
I have problem with VideoStudio X9 Ultimate, when i want to try fade in/out between video (see in video example)
https://www.youtube.com/watch?v=4EJ8HtDLSXQ
it's look like not going together with text fade out/in , the second video disappeared at the same time
please help
11suppakit
ram: 16 GB
Re: Please Help About Fade in/out
somebody els please help me :(
Terfyn
motherboard: ASUSTeK P8H61-MX
processor: Intel Corei5-2320
ram: 8Gb
Video Card: NVIDIA GeForce 210
sound_card: NVIDIA High Def Audio
Hard_Drive_Capacity: 1000 Gb
Monitor/Display Make & Model: Acer & LG
Corel programs: VS X10 and PSP X8
Post by Terfyn »
It is not clear what your problem is. There are "text 1", a spin of a coin and "text 2" I cannot see any fades. Plus everything is on overlay tracks.
IMO you need to clean up your layout, try two overlay tracks and a title track. Insert the transitions from the Transition Library and lengthen the spinning coin clip.
Plus give us more than 20 minutes to answer. Some of us have better things to do than keep a continuous watch on Forums.
11suppakit
ram: 16 GB
Terfyn wrote:It is not clear what your problem is. There are "text 1", a spin of a coin and "text 2" I cannot see any fades. Plus everything is on overlay tracks.
i was use VS X8 before and it have no problem. Maybe i should delete X9 and install with X8 again.
and now i have the problem when i remove X9 but can't install x8 it's said "You have installed another version"
please help
Your transitions are set to 1 second, that is pretty quick and not that noticeable. Change the default duration of the Transition effect to say 4 seconds.
Settings - Preferences (F6) – Edit tab
For existing projects transitions, select the transition and adjust duration using the digital clock.
You have also used two transitions (crossfades) when one may be better?
Have you managed to install Video Studio, if no, give us more information?
11suppakit
ram: 16 GB
lata wrote:Hi
it does not work. now I uninstall X9 with Revo Uninstaller (remove everything of X9) , but i can't install X8 it's said "I have installed another product"
How can i fix this problem?
I do not know why you cannot install video studio, did you try installing X8 and x9.
You may have been better using Windows Programs and Features to uninstall.
After using Revo the process then removes other leftover files, you did not by mistake remove the setup files, just a thought.
If you cannot install either version I would try System Restore to before Revo uninstall, Revo should have create a restore point.
11suppakit
ram: 16 GB
Can Video Studio X8 use on Windows 10 ?
I do not use Windows 10 so cannot say if X8 is fully functional, I am sure other Windows 10 users have X8 installed.
I found this info on the Corel site, interestingly does not list CVSX8
http://www.corel.com/gb/corel-and-windows-10/
11suppakit
ram: 16 GB
lata wrote:Hi
Thank you,
Now i have do video for more details about my issue (CVS X9) >> https://www.youtube.com/watch?v=A9X-1VdQBuc
(please watch with use annotations option. I have put some text on it.)
i do video that show how problem is.
Please save the project as a VSP file, Zip the VSP file and attach to your post
As you appear to be using the library sample clips we will be able to see exactly what effects you have applied.
The transitions used on the last YouTube were less than 1 second, so dragging the curser is done slowly not in real time as when playing the project.
How long in seconds do you want the crossfade ?
11suppakit
ram: 16 GB
Everything that I do with those effect I can use it the same way in X8 with no problem. (X8 with my old wins XP)
Issue that i get its all about Crossfade transition
I have no idea how to fix it :(
maybe i should down my windows to 7 or 8 for use X8
Can u suggest the windows that 'real support' with Corel Videostudio softwares?
I have viewed your video a few times but cannot see the problem you are having, maybe I am missing something.
Clearly dragging the curser is done in a different time as to playing the project.
That is why I suggested you provide the VSP project file then we can see exactly what you are doing.
If X8 worked ok do you have the Project Files from X8, they will open in X9 so you can compare timings.
I also commented on the duration of the transition, do you want that crossfade shorter than 1 second? Less than one second is not gonna be recognisable as a fade when played in real time.
Windows 10, as I said I do not use that so cannot really comment on X8, but would assume it should work? Others on the forum could confirm this.
I do not think the problems you are having are related to Windows 10
canuck
operating_system: Windows 8.1
Post by canuck »
11suppakit,
like Trevor I am having a very difficult time following what you are doing in that project. It is certainly a very confusing setup and trying to understand what you are doing in that video is almost impossible.
Why don't you do what Trevor asked and attach that vsp project file so that we can try to understand it.
Post by BrianCee »
how to add a file or image to your posts - - read - - http://forum.corel.com/EN/viewtopic.php?f=63&t=57659
