ASP3 - Updating MetaData on multiple images
Juicy
Corel programs: PaintShop2021Ult, Vid Studio X18
Post by Juicy »
Hello,
New guy question here.
How do I update the Metadata / IPTC tags on multiple images? While I can select multiple images and enter keywords that are then applied to all selected images as I would expect, this does not work with the Metadata; it only seems to update the one image that is displayed no matter how many are selected, leaving a rather large and tedious job to update many photos with the same desired values.
AS Pro v3.0.0.126.
Thank you to all for the help!
drgrumpy
operating_system: Linux
Corel programs: Aftershotpro3
Re: ASP3 - Updating MetaData on multiple images
Post by drgrumpy »
Yep this has been a real issue for me too. Their approach to basic IPTC data is poor at best. It is a real pain and has been deal breaker for me. It would make much more sense for it to work as in nearly every other metadata editor I have ever used as you indicate.. Completely non-intuitively you have to 'copy selective image settings' and then make sure you just select IPTC, then paste to the other images..... but beware it doesn't seem to even save the iptc metadata in the image file itself, only in its own xmp file, then worse still to make it available to other software you have to 'write standard xmp files'
