VideoStudio crashing upon launch
RLGDumfries
processor: 2.7 GHz intel core i5
ram: 8gb
Video Card: intel iris pro
Hard_Drive_Capacity: 1tb
Monitor/Display Make & Model: apple iMac
Post by RLGDumfries »
About 2-3 weeks ago, Video Studio started crashing right after I click to launch it. I uninstalled and reinstalled but that did not change anything and it told me that there were no updates available.
Below is the error message that is generated by windows. What is the solution to this problem? I am running windows 7.
Problem signature:
Problem Event Name: APPCRASH
Application Name: vstudio.exe
Application Version: 17.0.0.249
Application Timestamp: 52bb3bf3
Fault Module Name: vstudio.exe
Fault Module Version: 17.0.0.249
Fault Module Timestamp: 52bb3bf3
Exception Code: c0000005
Exception Offset: 000000000022362d
OS Version: 6.1.7601.2.1.0.768.3
Locale ID: 1033
Additional Information 1: b20a
Additional Information 2: b20a63fb09f772f93572abe583c2cd1b
Additional Information 3: f69f
Additional Information 4: f69f7a4830bf290e2167829855e5c256
RLGDumfries
ram: 8gb
Re: VideoStudio crashing upon launch
I just saw the post about the hotfix so I going to install that now.
Problem solved. Installing the hotfix worked.
Post by BrianCee »
Strange that you were told that there is no updates because your version number indicates that service pack 1 is not installed - the latest version number is 17.1.0.22
you should install service pack one - and definitely install the hotfix - you will find both of them here
http://www.videostudiopro.com/en/suppor ... sion-tab=2
RLGDumfries
ram: 8gb
Thanks. Will install SP1 soonest. Assume that having already installed the Hotfix will not be problem.
