I found some stupid typos in the lens profile, which costs me tree hours of my life to find out and fix.
May be Corel has no quality inspection...
Lens correction for the Sony RX100M4, as I mention here, does not work any longer.
lens-cameras-db.xml and lens-db.xml are now xml-files instead of txt-files in ASP 2.0.
lens-cameras-db.xml maps the Sony RX100M2, RX100M3 and RX100M4 to the -wrong!- Sony R1 Lens profile!
lens-db.xml contains only one profile for the RX100 and no profiles für RX100M2, RX100M3 and RX100M4.
Workaround:
add a RX100M4 Profile in lens-db.xml
Code: Select all
<Lens raw="true" skip="false">
<Model>Standard</Model>
<Mount>sonyRX100m4</Mount>
<FocalLength max="25.7" min="8.8"/>
<Aperture>0</Aperture>
<CropMultiplier>2.7</CropMultiplier>
<Converter factor="1" detected="false"/>
<CorrectionCoefficients>
<RadialDistortion focal="8.8" a="0.02266" b="-0.09581" c="0.00190"/>
<RadialDistortion focal="10.9" a="0.02376" b="-0.09457" c="0.03217"/>
<RadialDistortion focal="13.0" a="0.02326" b="-0.08674" c="0.04569"/>
<RadialDistortion focal="14.7" a="0.02340" b="-0.08395" c="0.04970"/>
<RadialDistortion focal="16.6" a="0.02045" b="-0.06253" c="0.02684"/>
<RadialDistortion focal="20.0" a="0.02295" b="-0.06814" c="0.05127"/>
<RadialDistortion focal="25.7" a="0.02377" b="-0.06078" c="0.04156"/>
</CorrectionCoefficients>
</Lens>
Code: Select all
<Camera skip="false">
<Maker>SONY</Maker>
<Model>DSC-RX100M4</Model>
</Camera>
Be careful while editing these files, one typo in these XML-Files will fail ASP to start! (I tried it!
Backup both original files before editing!
Andreas
