Luminosity Scripts - Revised 04/20/2017
csh2000
processor: Intel Core i7-6500U CPU 2.50GHz
ram: 12GB
Hard_Drive_Capacity: 1TB
Corel programs: PSP X9, Aftershot Pro 3, VideoStudio X9
Post by csh2000 »
I have created some luminosity scripts for PaintShop Pro. They were created and tested
in PSP X8, but should work with older versions without issue.
Update - These scripts store the masks in the alpha channels. Also included in the zip file is a script to facilitate creating a mask layer from any selection in the alpha channel
The creation of these scripts and the naming of the alpha channels are based on the
PhotoShop tutorials provided by Tony Kuyper. To understand how to use luminosity masks,
you should visit his website at http://goodlight.us/writing/luminositym ... sks-1.html
The luminosity scripts are a series of four scripts which create luminosity masks in
PaintShop Pro. The 'Lights' and 'Darks' scripts can be run independently if those are the
only the masks that you need. Alternatively, you can run 'Luminosity All Masks.PspScript'
to run all three scripts at one time..
These scripts should be installed in your Scripts-Restricted folder. For ease of use, I place
mine in a separate sub-folder called Scripts-Restricted\Luminosity Masks\.
Luminosity Lights.PspScript - Generate light luminosity masks
Lights, Lighter Lights, Bright Lights, Super Lights and Ultra Lights
Luminosity Darks.PspScript - Generate dark luminosity masks
Darks, Darker Darks, Shadow Darks, Super Darks, Ultra Darks
Luminosity Mid-tones.PspScript - Generate mid-tones luminosity masks based on 'Lights' and 'Darks'
Basic Mid-tones, Expanded Mid-tones, Wide Mid-tones, Super Mid-tones
Luminosity All Masks.PspScript - Runs all three scripts
(Luminosity Lights, Luminosity Darks and Luminosity Mid-Tones)
I have tested these on two different systems and have not experienced any issues. If you have issues with
these scripts or suggestions for improvements, please leave me a comment and I'll do my best to respond.
Kathy_9
Hard_Drive_Capacity: 2TB
Re: Luminosity Masking Scripts
Post by Kathy_9 »
It's very kind of you to share your work.
csh2000
ram: 12GB
Post by csh2000 »
I have updated the scripts with additional error checking as well as added two new scripts ('Dodge and Burn Layer' and 'Mask Layer from Alpha'). Instructions for each script are in comment section.
csh2000
ram: 12GB
Post by csh2000 »
I have updated the luminosity scripts. I was able double the speed of the three main scripts (Darks, Lights and Midtones) by turning the marquee off. The downside to this is that if you normally turn marquee off, then these scripts will turn the marquee back on when done as I can not find anyway to save previous setting.
Also, I changed the scripts to run in silent mode.
I modified scripts, please see latest update below.
Briansdad
motherboard: ROG STRIX Z690-A GAMING WIFI D4
processor: 12th Gen Intel Core i7-12700K 36
ram: 32GB
Video Card: NVIDIA GeForce RTX 3070 Ti
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: BenQ SW271
Corel programs: VideoStudio 2023
Post by Briansdad »
This is fantastic! Just what I was looking for! I've been stymied by Luminosity Masks up to now. Thank you! :D
Briansdad
ram: 32GB
Post by Briansdad »
Oh, no! :( I expected the masks to appear as layers after running the scripts (Paintshop Pro X9, SP1). I watched as the script created them and as they disappeared when the next was created. In the end, I had no masks, just the original image. What have I done wrong?
Bill
csh2000
ram: 12GB
Post by csh2000 »
Briansdad wrote:Oh, no! :( I expected the masks to appear as layers after running the scripts (Paintshop Pro X9, SP1). I watched as the script created them and as they disappeared when the next was created. In the end, I had no masks, just the original image. What have I done wrong?
Bill
Bill - The scripts save the data in the Alpha channel. It's easy to create a mask or selection from the Alpha channel. In the zip file, there is also a script "Mask Layer from Alpha" which helps facilitate this task. Let me know if you have other questions. I do not have PSPX9, but they should work fine there. as well.
Chip
Briansdad
ram: 32GB
Post by Briansdad »
Oh, found them in the alpha channel (running the alpha channel script). :) Have I got the gist of it now?
Bill
PS: This should be part of the Paintshop Pro packaged program!
kenh
processor: AMD Phenom II
Video Card: ATI Radeon HD5570
Monitor/Display Make & Model: Hanspree
Post by kenh »
Thanks for sharing the scripts, I have been thinking about trying to do this for a while.
cosmicDread
motherboard: MSI MPG Z390 Gaming PRO
processor: Intel Core i9-9900K
ram: 32 GB
Video Card: GeForce GTX 1080 Ti
Hard_Drive_Capacity: 6 TB
Monitor/Display Make & Model: Acer Predator X34
Corel programs: PaintShop X5, X6, X8, X9, '18, '19, '20
Post by cosmicDread »
Thanks for sharing. I put an interface on the masks code and added an HSL driver:
http://forum.corel.com/EN/viewtopic.php?f=104&t=61441
Charles B.
When the majority of the people on Earth are wanting the Galactic Federation to show themselves, then they will.
csh2000
ram: 12GB
Re: Luminosity Scripts
Post by csh2000 »
I've updated the luminosity scripts to fix a minor error and removed the requirement that these scripts be run on a raster layer. I've also added a few more scripts that I use for my photography. Install these in your "Restricted" folder.
- Generate light luminosity masks in Alpha Channel
- Generate dark luminosity masks in Alpha Channel
- Generate mid-tones luminosity masks in Alpha Channel
- Runs all three scripts (Luminosity Lights, Luminosity Darks and Luminosity Mid-Tones)
Load Mask From Alpha Channel.PspScript
- Runs 'Layers'| 'Load Mask From Alpha Channel' then renames mask layer to Alpha Channel selected.
Copy All Alpha Channels to Group.PspScript
- Create grey scale representation of all masks in the Alpha channel. This helps with visualization (opposed to small preview window). Use caution when creating as this could take a significant amount of time to create.
Copy Alpha Channel to Layer.PspScript
- Create grey scale representation of a single mask in the Alpha channel. This helps with visualization (opposed to small preview window). Also can be used to modify
image by layer blend modes. Try using 'Lighten' with Dark or mid-tone luminosity mask to lighten a dark image.
Select Brights From Image.PspScript
- Create Selection based on brightness of image. This is same luminosity selection as "Create Mask from Image".
Select Darks From Image.PspScript
- Create Selection based on darkness of image. This is same luminosity selection as "Create Mask from Image" (inverted).
File removed - See next post for revised scripts.
csh2000
ram: 12GB
Post by csh2000 »
I've tweaked the Luminosity Darks and Luminosity Lights scripts to gain additional performance over previous version. I found that I could use the existing data already in the Alpha Channels to build the new masks rather than duplicating and merging masks. This doubled the speed of each of the individual scripts (Lights and Darks). When running all three scripts there is only a 40% overall improvement as I have not found a way to speed up the mid-tone script.
I am attaching all the scripts below:
csh2000
ram: 12GB
Re: Luminosity Scripts - Revised 04/20/2017
Post by csh2000 »
I have updated the luminosity scripts to note that these scripts are now freely redistributed for non-commercial purposes only. I do ask that if you modify or reuse this code that you would please attribute original works to me. After nearly 18 years, I no longer use PSP and will not be creating nor updating any of my past scripts. I have enjoyed this community and have learned much from the community (especially Levi and Cassel).
Luminosity Scripts.zip
Revised Luminosity Scripts
(16.39 KiB) Downloaded 438 times
