AfterShot Pro 3 - Linux - Crash on loading pano as jpg
Bugs & Suggestions
AfterShot-at-Corel
operating_system: Linux
System_Drive: N/A
Post by AfterShot-at-Corel »
Loading a directory with jpg files under Linux leads to replicable crashes. I eliminated batches of files until I found one causing a crash. I then opened the panorama photo in gimp and saved it again. Now ASP3 could load the file. However ASP2 had no issue with the original file.
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Re: AfterShot Pro 3 - Linux - Crash on loading pano as jpg
Post by hannes_hab »
Yes I can confirm this - I have the same problems here (Panos from Autopano_Pro/Giga)! Opening and saving with gimp helps!
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
AfterShot-at-Corel
System_Drive: N/A
Thanks for your reply and confirmation. I'm using Autopano as well and ASP3 seems to have a problem with some of these files. Using gimp as an intermediate step to make it work is only an exceptional solution.
Since you are using Autopano, may I ask you if your are running into the same issue with squared brackets in file names (default setting in Autopano) as I have described it in my other posting? Thanks :)
hannes_hab
System_Drive: Z
ram: 16 GB
I am not using the default file names in Autopano!
regards Hannes
austria
grubernd
System_Drive: N/A
Post by grubernd »
i have experienced similar hickups and i don't use Autopano. my best guess is that something in the metadata section of the JPGs is causing ASP to choke. not the actual metadata, but how the library that saves the image is handling the various headers, sections etc. i haven't been able to track down the exact reason and/or lib yet.
Bibble since 2004. Aftershot until 2020. From then on darktable.
TexJoachim
System_Drive: Z
Post by TexJoachim »
I have experienced this as well. It seems AFP v3 has problems opening jpgs created by AFP v2.x and Lightzone on my Linux box over here.
