AfterShot Pro 2/3 - Linux - file not loading - [file name]
Bugs & Suggestions
AfterShot-at-Corel
operating_system: Linux
System_Drive: N/A
Post by AfterShot-at-Corel »
If a file name contains special characters like [ ] AfterShot will not load the file. After removing the squared brackets from the file name Aftershot has no issue with opening the files. Not sure if other special characters have the same effect.
AfterShot-at-Corel
System_Drive: N/A
Re: AfterShot Pro 2/3 - Linux - file not loading - [file nam
Thought I might post an output example from the command line ...
AfterShot2X64 /tmp/tmp01.jpg
Code: Select all
   bibp:KeywordList=""
   bibp:FolderFilter="tmp01.jpg"
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:QueueOnlyNewFiles="false"
   bibp:JobName=""
   bibp:PresetList=""/>
 </rdf:RDF>
</x:xmpmeta>
Container __CATALOG_ROOT__/assets/tmp
Adding master versions
Scanning file  "/tmp/tmp01.jpg"
**** Found an old file in the import "/tmp/tmp01.jpg"
Removed child refs
Importing: "/tmp/tmp01.jpg"
defaults:  "DefaultRendered.xmp"
Done waiting on  "tmp01.jpg"  with ID  DbID( 1 : 5001 )
QMutex: destroying locked mutex
Opening DB "/home/user/.AfterShot/cache"
Extracting RAW data:  "/tmp/tmp01.jpg"
AfterShot2X64 /tmp/tmp\[01\].jpg
Code: Select all
   bibp:KeywordList=""
   bibp:FolderFilter="tmp[01].jpg"
   bibp:QueueName=""
   bibp:QueueType="0"
   bibp:JobName=""
 </rdf:RDF>
</x:xmpmeta>
... that's it.
Neither of the above works with ASP3 trial version from the command line
AfterShot3X64 /tmp/tmp\[01\].jpg
Code: Select all
Ready
QSslSocket: cannot resolve SSLv2_client_method
QSslSocket: cannot resolve SSLv2_server_method
QObject::connect: No such signal QAction::trigger(bool)
QObject::connect:  (receiver name: 'Directory View')
Initializing file system view...
File: s: 31
File system view initialized.
No custom slideshow settings found
MultiImageView::doCursor() Invalid cursor mode
mode: 1
