AfterShorPro 3, Linux: Tiles Crash???
arsen_mikitov
- System_Drive: N/A
- motherboard: Intel DX58SO
- processor: Intel Core i7 CPU 920 2.67GHz
- ram: 6 Gb
- Video Card: NVIDIA Corporation GK104 [GeForce GTX 670]
- sound_card: Intel 82801JI [ICH10 Family] HD Audio Controller
- Hard_Drive_Capacity: 12 TB
- Monitor/Display Make & Model: DELL U3011 + Acer AL1916W (Dual Monitor)
- Corel programs: AfterShot Pro 3
Hello! Today I wanted to update the AfterShot version on 3. I have found a problem: After correction of geometry in zPerspector plug-in, the image is divided into squares. It occurs in viewing and on export. It is awful...
slm
- System_Drive: N/A
- motherboard: Hewlett Packard
- processor: Intel E8400
- ram: 4GB
- Video Card: NVidia Quadro NVS 290
- Monitor/Display Make & Model: Dell U2312HM
- Corel programs: AftershotPro
Re: AfterShorPro 3, Linux: Tiles Crash???
After you've made your correction with the zPerspector plugin, un-check the Grid check box (so it is no longer selected).
The grid should disappear, then export the image and it should be ok (I just tried this and it worked).
arsen_mikitov
- System_Drive: N/A
- ram: 6 Gb
Unfortunately, no way helps.
Correction of geometry is very important tool and without it AfterShot pro 3 - useless.
Somebody has found a way how to solve a problem?
Dear developers, what you think of it? I think that this problem needs to be solved urgently!
Hobgoblin
- System_Drive: N/A
Check out the dates on previous posts on this topic, do you think the word 'urgently' exists in Corel's vocabulary?arsen_mikitov wrote:<snip>
arsen_mikitov
- System_Drive: N/A
- ram: 6 Gb
Oooohh nooo!!! The same problem on the AfterShot Pro-2.4 x64 version.... Earlier I used AfterShot 32 bits - zPerspector had no problems. Sadly...
Time for search of alternative of Corel has come
arsen_mikitov
- System_Drive: N/A
- ram: 6 Gb
I have understood where a problem!!!
The image is divided into tiles if Sharpening is chosen!
If to disconnect Sharpening, then zPerspector works normally!
slm
- System_Drive: N/A
- ram: 4GB
I'm not sure I understand, in my zPerspector if the grid is unchecked as below, then it is not visible and will not be in the exported image. You can turn on the grid, make your adjustment, then turn it off but leave the plugin enabled. No ?
