Seems to be £36.00 Sterling to upgrade if you go through the applications - Check for Updates link.
Still seems too expensive to me.
Better to shell out for the ASP3 version of Gradfilter Pro at $14.00 and install that in ASP 2 Pro where it works fine.
You can then keep your carefully crafted customUI.txt, and any Lens Calibrations you have already created or enabled in /opt/AfterShot2(64-bit)/supportfiles/Profiles/LensProfiles.
Tamron Lens calibrations seem to have been dropped from ASP 3 but exist with calibrations in ASP 2, although not always enabled. Change calibrated: false to true - if calibration data is shown, in /opt/AfterShot2(64-bit)/supportfiles/Profiles/LensProfiles/profile_genericSLR.txt
HTH,
R.
