Saving project WITH authoring features AFTER making DVD and
dvd_maker1
- Corel programs: Corel VideoStudio Pro X5
Is it possible to save a project with all the features put in at the menu authoring / editing phase after burning the DVD and making an image at the end of the authoring process? I note that after I have authored a DVD putting in menus etc using VideoStudio Ultimate X9 and burn the DVD, and then later open the saved project to say make some modification to a menu etc, the newly opened project does not have the menus and editing that I did before the initial burning. I find I have to start ALL OVER again (from the Sharing screen) and re-enter all the menus and editing I did BEFORE I burnt the DVD. Is there a way in which I can save the project after burning so that when I open it again ALL the menus and their editing is still there? I re-call that this was possible on much EARLIER versions. Thanks.
Re: Saving project WITH authoring features AFTER making DVD
when you close the burner module you are prompted to save the project, that should save all your menu structure.
If you have continued to edit the project changing the length then any chapter points may be compromised.
When you open that project again, go directly to Share create disc and all your menu details should be intact.
dvd_maker1
Thanks, I will check that out, hopefully it will work thus saving me a lot of time.!
Earlier versions of Video Studio may not have saved all details but X9 afaik does a good job.
I did run a quick test to check this prior to my original post.
