Yes they are different and have different meanings. From these posts I can see that you are speaking about video frames - that is, about the individual images that are run together to give the effect of motion, which is what a video is. A picture frame is simply a frame that you put around a single image, just like the frame around a painting or picture that you hang on your wall except in PSP it's a digital frame around a digital image. PSP has some picture frames that you can add to images. You'll find them when you click on the menu item Image and then select Picture Frame... from the expanded menu that appears.vasilis wrote:...and when we talk for frames picture frame is different from video frame?
Create animation with staic images
JoeB
- ram: 8 GB
- Hard_Drive_Capacity: 4.6 TB
Re: Create animation with staic images
JoeB
Using PSP 2019 64bit
JoeB
vasilis
- sound_card: nvidia GTX 2060
- Hard_Drive_Capacity: 500 gb
- Monitor/Display Make & Model: ASUS G731GV
- Corel programs: VS 2020
Levifiction the hartpaul told me that i can import the static images to VS to create animation.i don't care if is animated gif.simply i want to create sort clips with animated handwritting.the conlcusion is that with PS and and another software can i do it?also i am confused about this :to photoshop we working with pictures frames or video frames?a frend of mine told me that take a short screenshots videos and with then create animated
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Then yes, simple answer, VideoStudio can do that. If you're just looking to animate and don't care what format the final result is in GIF, Video, etc. then VS can produce videos of animations. MotionBuilder3D can also produce animations. Free video editors can produce animations. I don't know how easy it is to animate handwriting in VisualStudio but it should be possible.
Photoshop imports the video then splits the video into individual images. So you're working with a video frame that was converted to a regular picture inside Photoshop.
vasilis
How can run together individual pictures to create the effect of motion joeb?
BJC
- Hard_Drive_Capacity: 1TB
- Corel programs: Videostudio X10 and 2020
First you need many many pictures each of the same scene but with slight difference in movement between pictures -- do you have that ???
if yes then just put them all into the timeline of videostudio one after the other and when you play you will see animation
OR
I am beginning to think you only have one still image and you want to make that move - is that so ?
can be done but involves very much work
AND
you commented earlier that you had asked in the videostudio forum and were not satisfied with the non answer so I did a search and found you had asked the same question a number of times over the last few years and every time you received a number of replies and suggestions but yet here you are asking again, Read the previous Videostudio topics again from the links below
viewtopic.php?f=1&t=59296&p=326968&hilit=
viewtopic.php?f=1&t=62451&p=348066&hilit=
viewtopic.php?f=1&t=62475&p=348314&hilit=
viewtopic.php?f=1&t=62501&p=348599&hilit=
OR
AND
- ehume
- motherboard: Gigabyte GA-Z87X-UD4H
- processor: i7 4770k
- Video Card: Intel HD4600 [iGPU]
- sound_card: no_sound_card
- Hard_Drive_Capacity: 512GB+4TB
- Monitor/Display Make & Model: Acer KN242HYL
- Corel programs: PSP 2018 32b & 64b, AS3 64b, PE5 64b
PSP7 came with Animationshop 3.0 (back in the JASC days). It linked gif files, among other things. Have things changed in the interim? Is AS3 available free on the web as abandonware?
