DVD Pictureshow 2 - picture flicker
murphinite
Post by murphinite »
When burning a slideshow to a DVD some photos flicker when played back on a TV - this does not happen when burning to a VCD - any ideas on how to fix this problem ? I have the anti-flickering option checked under preferences but flickering still occurs
JohnFC
Post by JohnFC »
Try the update for DPS
http://www.ulead.com/tech/dps/dps_ftp.htm
CD & DVD PictureShow 3.0 | DVD PictureShow 2.0 | DVD PictureShow 1.0
Ulead CD & DVD PictureShow 3.0 5 in1 Update Pack (Build Number: 3.0.1.8, Release Date: 2005/2/22)
Enhancements:
* Supports opening of project files from Disney Magic Artist featuring Ulead DVD PictureShow
* DVD output quality has been enhanced
Bugs Fixed:
* Fixed the burning failure
* Fixed the problem of losing text after saving a project
* Fixed the problem of having issues importing some projects which were created by previous versions
* Fixed the problem that the program could not run on Windows 2000 Professional SP4 with Norton Antivirus System Works 2003
* Fixed the problem that VCDs with photos could not be played back on the software DVD player or a stand-alone VCD player
JohnFC
Post by JohnFC »
Sorry - there is also an update for V2
http://www.ulead.com/tech/dps/dps_ftp_dps2.htm
murphinite
picture flicker
tried the updates but still experiencing the flicker - but thanks for the feedback - will keep trying
heinz-oz
Post by heinz-oz »
The flicker usually shows in areas of high detail or horizontal lines, right?
Use an image editor, like PhotoImpact, PS or the like and introduce a slight vertical motion blurr, 1 or 2 pixels worth of it should suffice. In PI you can run a batch conversion which doesn't take long and you don't have to do it for each image separately.
murphinite
picture filcker
that's correct - will give it a try - thanks
Josquire
Post by Josquire »
Hi, my mother-in-law has PictureShow 2.0 and is experiencing the picture flicker problem. She is thinking of upgrading to version 4 in an attempt to solve this problem. Is picture flicking a problem with v. 4?
Thanks in advance.
murphinite
picture flicker
not sure if picture flicker is still a problem in version 4 however it was in version 3 - I sugguest you try downloading the free trial version 4 and burn a test slideshow before purchasing the upgrade
Josquire
Post by Josquire »
Ok, I will try that. Does anyone who has the full version 4 still have flicker problems?
pasky
Post by pasky »
hi,
Please install the DVD PictureShow Update Patch . You can download it from:
http://ulead.com/tech/dps/dps_ftp.htm
Make sure that you have checked the "anti-flickering" option on the main menu.for more information on how to do this, please visit:
http://www.ulead.com/learning/dps/dps2_01_1.htm
goodluck folks :D
