recently I started working with ASP3. I discovered three problems that I hope can be fixed soon:
1. Problem in new highlight recovery
Because I just had just finished a photo needing highlight recovery using ASP2 I created a copy of this master file and looked at the result in ASP3. In ASP2 everything was ok. The new algorithm in ASP3 however seems to be problematic for some photos, creating a pink tint where white light was before the correction. Here is the sample image I talked about. One jpg was created in ASP2 the copy of this master version was converted to jpg in ASP3 no settings were changed.
Here is the ASP2 jpg:
https://drive.google.com/open?id=0B5aXN ... 2x5TXFYYms
And here is the same photo with same settings processed with ASP3:
https://drive.google.com/open?id=0B5aXN ... XlScS1JQ00
2. Limit one cloned eg circles
The second problem I found is a limitation that I think should be lifted. I had a photo with really much dust on a filter turning into many, many small blemishes in the photo. So I created circle clones to remove the blemishes using the new blemish remove tool. After I had created 42 circles I was told that I reached the maximal number and cannot create any more clones. Of course I needed two more
3. Size-problem minimizing/restoring the right sidebar
A third small problem I discovered is related to the sidebars. The right sidebar containing all the tools and plugins can be minimized clicking the right arrow minimize/maximize button. If you afterwards restore this bar by pressing the same button again it is restored but to a width that is too small. Its just wide enough to see the sliders but too small to also see the numeric values for the sliders positioned right of the sliders. At least in my linux version this is true. This should also be fixed because I would like to see the numeric values as well when restoring the sidebar.
Thanks a lot
Rainer
