After Shot Pro 3 - Images disappear
Bugs & Suggestions
Martin5000
motherboard: Gateway TBGM01
processor: 2.67 gigahertz Intel Core i7 920
ram: 12280 MB
Video Card: GeForce GTX 750
Hard_Drive_Capacity: 984.47 GB
Monitor/Display Make & Model: Hanns.G iH282
Corel programs: AfterShot Pro3
Re: After Shot Pro 3 - Images disappear
Post by Martin5000 »
So I uninstalled ASP 3, disabled my anti-virus and re-installed ASP 3.
Out of the box, the No Image seems to have disappeared but I also seem to have lost the histogram.These a Canon EOS T4i RAW files. Both the Standard Histogram and the Color / Curves are blank.
I closed ASP 3 and reopened. Now the histogram is showing, after a short delay when the image is selected. After the first selection, if I then return to the previous image the histogram display is marginally faster. closing and reopening ASP 3 doesn't change this
Installed the GradFilterPro. Seems to work.
Installed the Canon EOS 80D camera again. The magenta color cast is still there. The histogram shows the green channel displaced far to the left.
Spoke too soon. Lost the histogram again.
Closed and reopened, this time with Task Manager, also open. Every time I apply and un-apply one of the tools, the AfterShot.exe memory used goes up. As I click on each next image, memory usage really sky-rockets. A memory leak issue?
Dobly
motherboard: Asus K170-P D3
processor: Intel i5 6600K 3.5ghz
ram: 32gb
Video Card: AMD Radeon 270X
sound_card: Focusrite 2i4
Hard_Drive_Capacity: Heaps
Post by Dobly »
billlagr wrote:
Dobly - don't bother. It does the same thing under Mint. I've tested it against both Win 10 and Mint. Same problems.
I'd be interested to know what RAW format you are using - I'm .CR2 and from my (quick) scan here, it seems that a lot of the problems happen with .CR2's?
Corel's support suggestion was 'uninstall and reinstall'. It's ALREADY a clean install, the problems cropped up the very first time I used it!!!
Well I didn't build a new pc for it, but I did get to try it on Mint 17.3. You are right, exactly the same problem. I only load the app every few days now to see if there is an update. Thus far nothing. I just close it after that. Until they fix it there is no point.
In the meantime I am using Raw Therapee. I almost have that working with my own workflow (or rather I am learning how it does the stuff I need). It is not as fast going from one image to the next. Take a second or two each time you switch images. ASP is super fast at this (when it works). Other than that is does all the same stuff. Maybe even more.
Other than that RT is pretty amazing for 'free'. I'll use it until they fix ASP3.
<edit> BTW. I am using CR2 files out of my Canon 7d
Dobly
ram: 32gb
Post by Dobly »
Martin5000 wrote:Every time I apply and un-apply one of the tools, the AfterShot.exe memory used goes up. As I click on each next image, memory usage really sky-rockets. A memory leak issue?
I noted that earlier in this very thread. Every time you open and image or use a tool the memory used by the app goes up. It tends to start playing up around the 800mb mark.
larschristian
operating_system: Linux
System_Drive: N/A
motherboard: ASUS something
processor: AMD Phenom II X6 1090T Processor
Video Card: ATI radeon something
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Dell 2312HM + Samsung SM913v
Post by larschristian »
No image available....
How did this version pass beta testing??? Just crashing all the time. I can't use this version, and apparently I'm not the only one... :-(
:evil: :evil: :evil: :evil: :evil: :evil: :evil: :evil:
dFlyer
System_Drive: N/A
Post by dFlyer »
For linux crashing I discovered that some jpg were being miss read as tif. There are currently 2 ways to handle this, 1- delete the jpg one file at a time if you start from the command line ASP3. It will crash on the file and list it's name, or 2- After starting from the command line when ASP3 crashes and list the file causing it. Load that file in GIMP and export it as a jpg. Needless to say deleting file is a few steps shorter. All my raw files were importable so I can reprocess them.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
larschristian
System_Drive: N/A
Going around deleting jpg files is NOT a solution. It's not even a workaround. My jpgs are the ones developed by my camera. I can't just reprocess them.
Tried going back to ASP 2, but now it crashed after editing one image.
Tried to work without catalogs in ASP 3, but it still fails. No image available before I can edit.
Maybe it's something wrong with the parsing of XMP files?
larschristian
System_Drive: N/A
- Removed Aftershot2, Aftershot2x64 and Aftershot3x64 with apt-get purge.
- Deleted /tmp files
- Deleted everything under ~/.config/Corel
- Deleted ~/.AfterShot*
- Reinstalled ASP3
Seems to be working for now, but Corel really needs to find the source of this problem. :evil: I'm guessing I'll end up having the same problems again soon....
edit wow....bugged again 5 minutes after this post.... :cry:
larschristian
System_Drive: N/A
Seems like I found a solution. Deleted the last lines in ~/.config/Corel/AfterShot\ Pro\ v3.conf and the "No Image available" bug went away:
Here is a diff of the conf file before and after:
Code: Select all
lars@jernet ~/.config/Corel $ diff AfterShot\ Pro\ v3.conf /home/lars/tmp/asp-debug/***.conf
4c4
< CleanExit=false
> CleanExit=true
129c129
< LastRun\Tools\currentTab=1
> LastRun\Tools\currentTab=0
133,138c133
< LastRun\runs=2
< LastSelection\DBSelection\1\LastRun\SortDescending=false
< LastSelection\DBSelection\1\LastRun\SortMode=0
< LastSelection\DBSelection\1\Presets\Expanded\1\path=Presets/Black-and-White
< LastSelection\DBSelection\1\Presets\Expanded\size=1
< LastSelection\DBSelection\1\Presets\MenuItems\size=0
> LastRun\runs=1
145c140
< MainWindow\ViewMode=2
> MainWindow\ViewMode=0
147c142
< Preferences\Cache\runsSinceClean=1
> Preferences\Cache\runsSinceClean=0
189c184
< Preferences\lastSelectedPrefRow=0
> Preferences\lastSelectedPrefRow=6
196c191
< UberWindow\MIViewGeometry=@ByteArray(\x1\xd9\xd0\xcb\0\x2\0\0\0\0\x1\x43\0\0\0\0\0\0\x4\xe1\0\0\x3\xa7\0\0\x1\x43\0\0\0\0\0\0\x4\xe1\0\0\x3\xa7\0\0\0\0\0\0\0\0\a\x80)
> UberWindow\MIViewGeometry=@ByteArray(\x1\xd9\xd0\xcb\0\x2\0\0\0\0\0\0\0\0\0\0\0\0\x4\xe1\0\0\x3\xa7\0\0\0\0\0\0\0\0\0\0\x4\xe1\0\0\x3\xa7\0\0\0\0\0\0\0\0\a\x80)
202c197
< UberWindow\count=1
> UberWindow\count=0
214c209
< UberWindow\thumbViewHotness=
> UberWindow\thumbViewHotness="4,279"
216c211
< UberWindow\thumbViewSelection=
> UberWindow\thumbViewSelection="4,279"
Needs further investigation, but I'm hoping for a solution sooon... :?
A little warning: The license key is stored in the conf file, so don't post your conf files without editing your license key out!
scoutr2d2
motherboard: Notebook
processor: intel i7
Video Card: Nvidia 650M
sound_card: does not matter
Corel programs: Aftershot
Post by scoutr2d2 »
Hey Guys a tip to try is to switch off the hardware acceleration from the grafic card. On the Mac book it seems to work. Greetz Achim
twan052
operating_system: Mac
System_Drive: N/A
motherboard: Gigabyte GA-z87x-udh3
processor: Intel Core I7
Video Card: Intel HD4600
Hard_Drive_Capacity: 3TB
Monitor/Display Make & Model: Dell-u2713h
Corel programs: Aftershot Pro
Post by twan052 »
Hi Guys ,
I have tested on Mac El Capitan 10.11.5.
Opencl on/off and OpenCL Utilization minium/maxium it doesn't affect this bug.
Furthermore, I have sent a message regarding this bug to
Corel via Facebook messages.
Hopefully I'll get a response soon from Corel
Regards, Twan
bear_sk
System_Drive: N/A
Post by bear_sk »
Same "No image available" on my setup (system info attached). I keep restarting after opening 5-50 images. Annoying
systeminfo.txt
system info
(1.37 KiB) Downloaded 299 times
Dobly
ram: 32gb
Post by Dobly »
The chap handling my support ticket (or not handling it) suggested I uninstall ASP3 and reinstall it.
I did that. Seemed ok for the first minute or so. But then i hit the number 5 on an image to rate it. The image on the right disappeared.
Dobly
ram: 32gb
Post by Dobly »
scoutr2d2 wrote:Hey Guys a tip to try is to switch off the hardware acceleration from the grafic card. On the Mac book it seems to work. Greetz Achim
I tried that.. Made no difference on Windows 10
dFlyer
System_Drive: N/A
Post by dFlyer »
Dobly wrote:The chap handling my support ticket (or not handling it) suggested I uninstall ASP3 and reinstall it.
Same thing here with linux. The suggested I uninstall and reinstall which I did with no change. Then they said that I should create a new admin user and install under that account which I did. Still no change to error message jpg being read as tif.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Kneops
System_Drive: N/A
motherboard: ASUS P8 Z68
processor: Intel i7 2600
Video Card: nVidia 450
sound_card: onboard
Hard_Drive_Capacity: 14 TB
Monitor/Display Make & Model: Dell U2713H & Spider4
Corel programs: ASP3
Post by Kneops »
One month since the release of this version. Almost no communication about this and people who bought the new version can't use it (I didn't buy it yet).
1/12 x price = refund.
