Hi all, has soemone already tested the customToolsUI.txt
I just copied mine from Version ASP2 to the Testinstall ASP3 and after that ASP3 istn't starting or crashes at the state when trying to build up the menus. After deleteing the customToolsUI.txt ASP3 is working again.
Any ideas or hints?
Martin
ASP 3 customToolsUI
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Re: ASP 3 customToolsUI
customToolsUI.txt is working here! You have to check the changes.
so here
Lens, L, Advanced/LensCorrection.ui (has changed to) Lens, L, Advanced/LensCorrectionWrapper.ui
WM, Wm, Watermark.ui is new
and so on ...
(see /opt/AfterShot3(64-bit)/supportfiles/tools/)
delete Plugin uis that you don't use
I noticed that is is necessary to install the plugins from ASP - coping the folder "Plugins (64-bit)" is not working for all plugins
so here
and so on ...
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
malepo
- System_Drive: N/A
- processor: Intel
- Video Card: Nvidia
- sound_card: Intel
- Hard_Drive_Capacity: 690GB
- Monitor/Display Make & Model: acer
- Corel programs: AS1, AS2, PSPX8
Thanks Hannes, I tried a lot so far.
with AS2 it doesn't matter whether the UI was available or not; AS2 irgnored that row - AS3 is just crashing.
Last line in LOG says "Using customToolsUI.txt" and that's it, so that's not that easy.
Martin
Martin
hannes_hab
- System_Drive: Z
- ram: 16 GB
I tested it only on linux so far ...
regards Hannes
austria
austria
malepo
- System_Drive: N/A
- processor: Intel
- sound_card: Intel
ok, I give up.
from what I found its crashing due to some QT5 libraries.
well AS3 feels faster and I would have give it a go, but not if this isn't working here
Thanks an cheers
Martin
Thanks an cheers
Martin
