v.3 won't support Pentax PEF RAW format.
Bugs & Suggestions
nick-in-wales
operating_system: Linux
System_Drive: N/A
processor: Intel i5 4690
ram: 24GB
Hard_Drive_Capacity: 3TB
Corel programs: Aftershot Pro 3.
Post by nick-in-wales »
First post from a desperate user!
I've been using v.2 of Aftershot Pro for a few months and I've been really happy with it, I had a notification that v.3 was available so I've paid up only to find I now can't see my Pentax RAW (PEF) files in the editing window, I can see the thumbnails but not the big image. v.2 worked (and still works) perfectly but v.3 seems broken to me. I use a Pentax K3 and I'm running on Ubuntu 14.04LTS, has anyone else got a problem? :(
Nick
Pentax and Ricoh for Ever!
I love Linux!!
It's wet in Wales, always.
Catire
motherboard: hphphphp
processor: intel core 17
ram: 8gb
Video Card: nVidia
sound_card: Control beats
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: hp
Re: v.3 won't support Pentax PEF RAW format.
Post by Catire »
That's odd. Mine are showing up. I'm using win8.1.
Hobgoblin
System_Drive: N/A
Post by Hobgoblin »
Seems to be working fine with .pef from Pentax K-5.
However all of the Tamron Lens Calibrations are now gone, and there is no easy way to edit them as previously.
As I said elsewhere, I off to Darktable. :wink:
kkoether
motherboard: ASUS P5K
processor: Intel Core2 Duo
Video Card: GeForce 720
sound_card: Sound
Hard_Drive_Capacity: 5TB
Corel programs: Aftershot Pro 2, Paintshop X8
Post by kkoether »
I downloaded the trial. It see's PEF's from my K200D but doesn't see PEF's from my K-3. I opened a support ticket but I can't seem to get them a PEF file from my K-3 to verify the issue. Guess I WON'T be buying Version 3.
nick-in-wales
System_Drive: N/A
ram: 24GB
I can supply a K3 PEF file but so far Corel haven't asked for one, in fact they don't seem to be interested in my case at all, Ticket (3638657). Their advice seems to revolve around "try re-installing ASP3", what next? Try turning you computer off and on again, or re-installing your operating system? I even dug out a laptop, loaded a fresh install of Ubuntu 16.04 and in that case ASP3 wouldn't even run at all.
This what I've had them so far:
I've done that, same problem.
I have also renamed the config file, restarted ASP3 so it created a new config file and still it won't open PEF images. ASP2 still opens them perfectly. I have also tried removing ASP2, installing ASP3 again and still no support for PEF. A number of people on the forum have the same problem.
Any more suggestions?
Nick
On 16/05/16 19:29, Corel Customer Support wrote:
> ##- Please type your reply above this line -##
> Your request (3638657) has been updated. To add additional comments, reply to this email.
> Cho
> Cho (Corel)
> May 16, 14:29
> Nick Randall-Smith,
> Thank you for contacting Corel Technical Support.
> Sorry about that, I would recommend reinstalling your ASP3 and see if there'll be differences.
> Please do not hesitate to contact us with any further questions.
> Regards,
> Cho
> Corel Technical Support Services
> Nick Randa
> Nick Randall-Smith
> May 13, 12:59
> Hi,
> Thanks for the reply but your instructions are for a Windows system and
> as I explained below my computer is running a version of Linux, Ubuntu
> 14.04 (64 bit).
> Any other suggestions?
> Nick
> Cho
> Cho (Corel)
> May 13, 12:40
> Nick Randall-Smith,
> I appreciate bringing your query to our attention. I suggest resetting your ASP3 by following the steps below.
> 1. Open File Explorer.
> 2. Go to C:\Users\[YOUR_USERNAME]\AppData\Local\Corel.
> 3. Rename "AfterShot 2" to "AfterShot 2_OLD".
> You also need to delete your temporary files. Here's how to delete them:
> 1. Press the Windows logo and 'R' on your keyboard to show up the Run window..
I love Linux!!
nick-in-wales
System_Drive: N/A
ram: 24GB
An update: Corel have asked for my camera model, a K3.
I also sent them this:
More information for you.
I created a new folder full of new PEF files, I then imported the contents of that folder into ASP2 and all worked perfectly, I could see and manipulate the files.
I then carried out the same process using new PEF files using ASP3, ASP3 could see the folder but failed to import the files.
I then checked with ASP2, it could see the folder created by ASP3 but could would not import the files into it.
I deleted the "empty" folder reference in ASP2, closed ASP2 and restarted it. once again ASP2 was asked to import the folder, it created the folder but did not import the PEF files.
I now created some more PEF files with my camera, copied them onto my hard drive and then imported them into ASP2, all worked perfectly. I then opened the same folder with ASP3 and I could see the thumbnails but they would not open in the editing window. I closed ASP3 and opened ASP2, I could see both the thumbnails and edit them.
I then asked ASP2 to open the file in Aftershot HDR and there was no problem. I then did the same with the same file under ASP3 and Aftershot HDR and got "load image failed".
I can supply a PEF files with associated XMP if that helps.
I love Linux!!
arsen_mikitov
System_Drive: N/A
motherboard: Intel DX58SO
processor: Intel Core i7 CPU 920 2.67GHz
ram: 6 Gb
Video Card: NVIDIA Corporation GK104 [GeForce GTX 670]
sound_card: Intel 82801JI [ICH10 Family] HD Audio Controller
Hard_Drive_Capacity: 12 TB
Monitor/Display Make & Model: DELL U3011 + Acer AL1916W (Dual Monitor)
Corel programs: AfterShot Pro 3
Post by arsen_mikitov »
Yes, I have a same problem. Linux Ubuntu 16.04. AfterShot Pro-3 doesn't read the Pentax K-3 files (PEF).
I don't understand Corel.
Yes, there are no alternatives for linux users, but I would like that they solved such serious problems as fast as possible.
uliw
System_Drive: Z
Hard_Drive_Capacity: 2 TB
Post by uliw »
same issue with the K3-II. ASP 2.4 would open the dng of the K3-II, but ASP 3 does not....
Alex Brazeau
operating_system: Windows 8.1
Post by Alex Brazeau »
uliw wrote:K3-II, but ASP 3 does not....
Can you send me some sample PEFs from the K3-II? We're doing some testing in ASP3 and I'm looking for sample shots with different exposures, focal length, lenses, ISO and/or with a color chart. If you can supply some samples, please reply here or send me a PM with a Drive or Dropbox link. Thanks
madbrain
motherboard: Gigabyte GA-990FX-UD3
processor: AMD FX-8350
ram: 32GB
Video Card: nVidia GTX 750Ti
sound_card: ECHO Audiofire 12
Monitor/Display Make & Model: HP LP3065 30" x 2 + Asus PA238Q 23" x 1
Post by madbrain »
FYI, it works with my PEFs from the older K200D .
burncpt
motherboard: Asus H170-PLUS D3
processor: Intel i5-6500
Video Card: nVidia geforce 780
sound_card: onboard
Hard_Drive_Capacity: 480GB
Monitor/Display Make & Model: ASUS VS247HR
Corel programs: Aftershot 3, PSP 2018, PSP X8
Post by burncpt »
Hi Guys,
Has this issue been resolved at all? I just bought Aftershot 3 because my copy of PSP X8 didn't work with .ARW files from the Sony A7ii but now I find that AS3 doesn't work with .PEF files from my Pentax K3ii. I saw this thread is a couple of years old and wondered if there was a fix now? I have the latest version (or at least the updater tells me so). I'm currently in the ridiculous situation of having to use AS3 for the Sony files and the built-in RAW processing in PSP X8 for the Pentax files - I'd really like the benefit of the better highlight recovery options in AS3, particularly as I had both cameras at a wedding shoot in challenging backlit conditions.
Thanks,
Chris
Voiceofexperience
motherboard: ASRock
processor: AMD FX-4300
ram: 32 gb
Video Card: AMD Radeon 7 200
Hard_Drive_Capacity: 5 tb
Monitor/Display Make & Model: LG S-IPS
Corel programs: None - I'm fussy.
Post by Voiceofexperience »
burncpt wrote: I'd really like the benefit of the better highlight recovery options in AS3
You're in the wrong place for highlight recovery, Chris - AfterShot Pro is far and away, and by an order of magnitude the most inept, least capable, most dismally under-performing, commercially available Raw converter out there, where highlight recovery is concerned.
Seriously: if that's a priority for you, you need to run, not walk, to another converter. This one is - literally - as bad as it gets if you value image quality.
burncpt
sound_card: onboard
Post by burncpt »
Well OK then - can you point me the right way then? Telling me it's terrible is all very well but doesn't help with making it work or finding a suitable alternative...
Many thanks,
Chris
hannes_hab
System_Drive: Z
motherboard: ASUSTeK P8H77-I
processor: Intel Core i7 3770K 3.5 GHz x 8
ram: 16 GB
Video Card: AMD Radeon R7 200 Series
sound_card: Radeon HD 7700 7800 Sapphire
Hard_Drive_Capacity: 2x250GbSSD
Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
Corel programs: AfterShotPro 1, 2, (3)
Post by hannes_hab »
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
josephlin
Alludo
motherboard: Intel Z490 chipset
processor: Intel Core i9-10900K
ram: 32GB
Video Card: nVidia RTX 2070S
sound_card: Realtek ALC892
Hard_Drive_Capacity: SSD 1TB
Post by josephlin »
Have you tried to update ASP version to v3.4? We can confirm both of Pentax K-3 or K-3 II PEF sample could be supported with ASP3.4 correctly. You can download the v3.4 patch from https://www.aftershotpro.com/en/support/updates/. If you still encounter the problem with K-3 or K-3 II sample, please raise the issue to Corel support team.
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
