I have been using Filtermeister plugins forever.
Until a few days ago, all worked perfectly.
Now, however, I cannot get most of them to work.
I run X8 on Win 10.
I get the following:
Runtime Exception
Memory Access Violation
Filtermiester Segment Register Contents
ds=0X002b
fs=0X0053
gs=0X002b
cs=OXoo23
eip=0X1C623c34
I did a system restore~~no help.
I reset X8 to default. No help.
I booted up X6 and they worked for a short time.
Same with X7.
I am desperate.
So hoping someone can help me.
I've spent hours and hours to no avail.
Thanks for any help,
Leslie
Filtermiester Problems
Leslie
- processor: intel core i7
- ram: 32 gb
- Video Card: intel iris
- Hard_Drive_Capacity: 1 TB
- Monitor/Display Make & Model: Dell Inspiron 7700 27 All-in-One Desktop
- Corel programs: 2019 Ultimate, 2022 Ultimate
Kathy_9
- Hard_Drive_Capacity: 2TB
Re: Filtermiester Problems
Leslie - here's some info that might help you http://thepluginsite.com/knowhow/tutori ... tion.htm#8
Leslie
- ram: 32 gb
Hi, Kathy
Thanks for the link, but I've already been there.
I have my psp exempted from DEP.
The plugins cannot be patched with the FM Patcher, nor can they be imported into Filters Unlimited.
The odd thing is that they stopped working virtually overnite.
Got a plan B for me?
Kathy_9
Sounds like you've already tried everything that I would do. You mentioned your plug-ins can't be patched with FM Patcher or be imported into Filters Unlimited; are you getting an error message of some sort?
Leslie
- ram: 32 gb
Yup. Lots of error messages.
Runtime Exception
ds=0X002b
fs=0X0053
gs=0X002b
cs=OXoo23
eip=0X1C623c34
Edited to add: The error message is when I try to use the plugin. FU says they aren't an FU plugin. No error from FU.
Do you think it might be a computer issue instead of a plugin one? Altho, I did do a system restore.
Runtime Exception
ds=0X002b
fs=0X0053
gs=0X002b
cs=OXoo23
eip=0X1C623c34
Kathy_9
That definitely sounds like a DEP related error. I'm having no issues on Windows 7 Professional; maybe a Windows 10 issue? I have heard that Windows 10 will install updates whether you want them or not. Is it possible that an update removed your DEP exclusions? You might want to check and see if PSP 32-bit is still excluded.
Also, I'm using the original version of PSPX8 and do not have either of the two service packs installed.
Leslie
- ram: 32 gb
I completely uninstalled X8, re-installed and did the DEP again. Just resetting to default didn't work.
Working now.
Having to redo all the file locations is taking me all day.
Well, at least it's fixed.
Thanks, Kathy. Appreciate your help.
Leslie
Working now.
Leslie
Kathy_9
Glad you got it working. I'm a plug-in junkie so I know how frustrating it is when they don't work.
