Introducing the New AfterShot Pro 3
coralian65
- motherboard: Samsung 700Z4A
- processor: Intel Core i5-2430M
- ram: 6gb
- Video Card: Intel HD Graphics 3000
- sound_card: Realtex
- Hard_Drive_Capacity: 750gb
- Monitor/Display Make & Model: Samsung N700Z4A laptop + HP w2207h external
- Corel programs: AfterShot Pro2
Re: Introducing the New AfterShot Pro 3
Sorry to repeat a reply made elsewhere but this seems a good place to bring this up. Much to like in this new version, but after working on a few CR2 files, when I move to the next thumbnail I get 'No Image Preview,' and there is no histogram or functioning adjustments available, If I shut down and restart everything works fine for a few more images and then the same thing happens. Very frustrating. Also happens in Slideshow. If I select all and try to view a show, I get a few files then a white rectangle. Sticking with version 2 until this is sorted and wish I'd not upgraded so soon.
Alan
Alan
Greg Wood
Hi Art,Art wrote:Highlight Recovery needs more work!
I saw in the comparison list that highlight recovery had been improved in ASP3, so I downloaded the trial version. To my dismay, it seems to be a work in progress. As others have mentioned, highlights can turn pink when moving the slider to the right. This occurred with one of my images at a setting of 18 on the scale that goes to 100. On other images, there doesn't seem to be a problem with highlights turning pink.
Moreover, I found that using both the recovery slider in combination with the highlight range slider, resulted in images becoming extremely blurry; the more I moved the sliders to the right, the worse the images got.
Art
Greg Wood here from the AfterShot Pro product team. Pink Hue on selected images has been reported on a few cameras, and we are working to reproduce this. Would you mind PMing me your camera details, or better yet, emailing me a sample (problem) RAW image at sample image <at> corel <dot> com? It would be very helpful as we try and chase down this intermittently reported issue.
Sincerely
Greg
Greg Wood
Re: Big Disappointment
[quote="grcolts"]Ditto for me too. I downloaded the trial version of ASP3 and have been playing around with it. So far, it has occasionally crashed on me, and when using the new highlight control found that it occasionally turns your highlights pink when pushed too far. A stable ASP3 without adding anything new would have pleased me as well. And, the watermarking feature is nice to have available but is it not the same as the plug-in ztext?
Hopefully, Corel will quickly fix those problems.
Cheers.
GR
Hi GR,
Greg Wood here from the Corel PM team for AfterShot Pro. We're working to resolve the intermittent reports of pink hue that we've seen. Can you please post your camera model info or better, email a sample RAW file to sample image<at>corel<dot>com? Thanks.
Greg
Cheers.
GR
Hi GR,
Greg
hannes_hab
- System_Drive: Z
- motherboard: ASUSTeK P8H77-I
- processor: Intel Core i7 3770K 3.5 GHz x 8
- ram: 16 GB
- Video Card: AMD Radeon R7 200 Series
- sound_card: Radeon HD 7700 7800 Sapphire
- Hard_Drive_Capacity: 2x250GbSSD
- Monitor/Display Make & Model: LG IPS 21:9 UltraWide 34UM95-P 3440x1440
- Corel programs: AfterShotPro 1, 2, (3)
Yes indeed! But its better now.by Art » Sat May 14, 2016 2:29 pm
I have experimented with layers (Highlight Recovery in regions on layers) and the SelectiveColor Tool (to reduce saturation of the pink color and/or change the hue and lightness) and the Equalizer Tool (sometimes also BEZ-plugin and GradFilterPro).
But still, with much more work, not as good results as I can achieve with photivo.
I will post an example later ...
I also have problems - with all of my cameras! But I have a workaround explained above. With exptreme blown highlights sometime its better to set exposure to -2 EV (sky and full southern sunlight).by Greg Wood » Tue May 31, 2016 6:47 pm
Greg - do you mean sampleimage<at>corel<dot>com or image<at>corel<dot>com?
regards Hannes
austria
Nikon D7000 + D70, Nikon P6000, Nikon P330 (use P7800) PanasonicTZ100, Vuescan
bibble 4, bibble 5, ASP mostly on Ubuntu 14.04 ( sometimes Suse Linux 11.4 or WIN10)
austria
rp9
- System_Drive: L
- processor: C2 Duo
- ram: 5GB
I have the same issue as discribed above. Removing config file is actually not a solution, because the only thing it does is that ASP3 do not scan the same directory on the startup and therefore does not crash. Also, on my MAC it works correctly, on linux crashes. Alex, is there any progress on that?tony_redink2000 wrote:I came across the same problem on a Linux system. After a few attempts, I found removing AftershotPro config file helped.rlebleu wrote:Looks pretty good. Crashes on some images on my Win10 system though. ...
146785.609: TIFF Error: C:/Users/Dick/Desktop/369440main_lroc_apollo11_lrg.jpg "Not a TIFF file, bad magic number 55551 (0xd8ff)"
Dick
rm ".config/Corel/AfterShot Pro v3.conf"
I'm not sure if Windows installs have the same file locations.
johnatyandoit
- motherboard: unknown
- processor: i7-4770
- Video Card: Intel integrated
- sound_card: Intel
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Dell U3011
- Corel programs: AfterShot Pro 3
Application crash on loading some files...
Some JPG files can produce this error in the log file WITHOUT crashing the application, others produce the error and DO cause a crash.
I can't attach the files here because of size restrictions of this forum (max 950px wide). The original file causes the crash. The same file, after loading and exporting from Gimp, does not cause the crash. If Corel Support can give me an email, I can send the files.
blueridge22
Corel,
Aftershot3 pro is not usable because it cannot import jpegs which it creates from Nikon exif or jpegs which it AfterShot2 pro created. This is really really BAD.
I ran the program under gdb got the set fault and did a bt (back trace)
(gdb) bt
#0 0x00000000009a8778 in JpegCompressor::finish() ()
#1 0x0000000000943b6b in JpegReader::extractJpegThumb(char**, int*) ()
#2 0x000000000096ab8b in CameraReader::extractJpegThumb(char**, int*) ()
#3 0x0000000000583d2f in OriginalThumbAsset::runInline() ()
#4 0x0000000000569a76 in FolderImportAsset::addMastersVersions() ()
#5 0x000000000056e4cf in FolderImportAsset::run() ()
#6 0x000000000083771f in ThreadMangler::runTask(TmTask&, TMMangler&, TMMangler::ThreadData&, TMResource&, TMMangler::Private&, bool) [clone .isra.46] ()
#7 0x0000000000837e5d in TMThread::run() ()
#8 0x00007ffff1d17514 in ?? () from /opt/AfterShot3(64-bit)/lib/libQt5Core.so.5
#9 0x00007ffff1a5f184 in start_thread (arg=0x7fffd48e1700) at pthread_create.c:312
#10 0x00007ffff0cdd37d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:111
I really dont understand why corel cannot fix this problem. It really makes the program not usable
Chip
(gdb) bt
Chip
tony_redink2000 wrote:rlebleu wrote:Looks pretty good. Crashes on some images on my Win10 system though. Tried to open a top folder containing subfolders of images, and ASP3 crashed. After investigation, I found the ASP3 log file to see if I could figure out why. Log indicated the following error:
146785.599: Scanning file "C:/Users/Dick/Desktop/369440main_lroc_apollo11_lrg.jpg"
146785.604: Importing: "C:/Users/Dick/Desktop/369440main_lroc_apollo11_lrg.jpg"
Removed the image file from the folder, and ASP3 opened fine without crashing. But I found many other instances in my image library where image files crashed the program. ASP3 log file identified the same error for the problem files...
Copied the problem file to my Macbook Pro running El Capitan, and ASP3 worked fine there...
Dick
All Media Lab
Hi there,
Very disappointing my first experience with Aftershot3.
Luckily Adobe has a free DNG converter so I was able to test my Canon 80d shots in Adobe Camera Raw (Photoshop CS5.5) and in the Free Canon RAW editor (Digital Photo Professional) that I got
with the camera to compare the results with Aftershot 3.
To be honest I don't see much difference between Aftershot Pro 2 and 3 besides worse image quality, a couple of new parameters, the 2 changed in 3 and a plenty of freezes in the application.
Lot's of times I get "No image available" when clicking from one image to the other, and Aftershot3 stops working.
It's nice to advertise with the speed it's loading, but I prefer top notch quality imaging. (I have my doubts about the faster loading, because it loaded at the same speed as importing in Adobe Bridge!)
I'm talking about the use of Canon 80D RAW files here.
When I change the parameters the image starts moving in a strange way!
When using multiple camera's the application crashes. In this case I used Canon 50d and Canon 80d. Opening and closing the application in between did not help either.
The image also degrades soon when zooming in. I'm talking about a 24mpix image at a 100% zoom. In Camera RAW from Adobe and Digital Photo Professional from Canon the image looks fine at the same size and zoom.
There seems to be a sharpness problem as well, because compare to Canon Digital Photo Professional and Adobe Camera RAW my images look not so sharp and materials like cloth, hair or fair less defined.
Canon EF 50m/m 1.4 USM:
Enable vignette correction creates vignette instead of takes them away!
Chromatic aberration does nothing, because it's parameters are on 0 (how are you supposed to know the adjustment? That needs to go automatically!).
The "Checking for updates" panel that appears after clicking "Check for updates" has the wrong font color (black on dark grey) and is unreadable.
Seems that I have paid to beta test the application.
Hope there will be a update soon, because I try to stay away from Adobe!
David
David
Ernie
- processor: i3 4350 3.6Ghz
- ram: 16 Gb
- Hard_Drive_Capacity: 3.5 TB int
- Monitor/Display Make & Model: Asus
- Corel programs: PaintshoPro X7,x9& 2019 Aftershot3
Hi All,
I am completely confused as to the difference between AS 3 & ASP 3. On Corel's site when I try a comparison I only get Comparison of Pro 3 to Lightroom etc.
I am in a quandry as to whether to purchase PSP X9 Ultimate with AS 3, or to purchase ASP 3 stand alone. I am currently using PSP X7 and am very satisfied (I've been using Corel since X2) so don't really need an update @ this stage.
I have spent hours searching for a difference (even tried AS 2 comparison - that didn't work).
So would Corel PLEASE create a comparison list as they do for various versions of PSP.
Additionally the Corel Website Advert for X9 Ultimate indicates AS 3 on their list & box. BUT the screen shot for AS shows ASP 3 in lower left corner - very confusing.
I look forward to Corel's reply.
blueridge22
Now that the tiff error has been fixed I am very happy.
This product runs on Linux and since it is what I have, it works great.
Chip
Chip
Has Corel Fixed Highlights Turning Pink/Magenta?
A while back there were several posts (including one by me) about blown highlights turning pink/magenta after using the Highlight Recovery Slider in ASP 3. Can anyone confirm that this has been resolved? Corel has an upgrade special on ASP 3 for $30, but the 30-day trial period for my ASP 3 has lapsed so I can't verify for myself.
hannes_hab
- System_Drive: Z
- ram: 16 GB
that is solved now - much better highlight recovery now - but many other things are still not solved.
see also: http://forum.corel.com/EN/viewtopic.php?f=90&t=60339
regards Hannes
austria
austria
Voiceofexperience
- motherboard: ASRock
- processor: AMD FX-4300
- ram: 32 gb
- Video Card: AMD Radeon 7 200
- Hard_Drive_Capacity: 5 tb
- Monitor/Display Make & Model: LG S-IPS
- Corel programs: None - I'm fussy.
Better as in "better than it was/as good as you're likely to get from AfterShot Pro" or as in "it now holds its own with the competition"?hannes_hab wrote:much better highlight recovery now
Not the latter, I imagine...
