ASP-3 and Linux
dFlyer
- System_Drive: N/A
ASP-3 and Linux
This morning got an upgrade notice that ASP3 was out so went and downloaded and installed the trial upgrade. I'm using Ubuntu 16.04-LTS, still not the stablest yet but will run ASP2,4. Couldn't find any install instructions so just installed it along side ASP2.4. The first problem I noticed was that it didn't give me a launch icon so went to /opt/ ASP3 folder and clicked on the bin file which started ASP3. The program seems to start very fast. Clicked on a folder to bring up some photos, the system crashed, so went an uninstalled it. Decided I would try to research the problem and found the TECH SPECS page which I've provided a link for:
http://www.aftershotpro.com/en/products ... tech-specs
I see it supports Windows and MAC, but no linux.
Before I put out any more money on this program, would like to see upgrade instructions for linux and be reassured that linux will continue to have support and work out of box without modifications.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Greg Wood
Re: ASP-3 and Linux
Hi dFlyer.
We have a snafu on that page--Linux is supported. We're working to update that content. You can grab Deb/RPM trials from http://www.aftershotpro.com/en/free-tri ... t-pro.html
Greg
Greg
Re: ASP-3 and Linux
I'm running Ubuntu 16.04 x64. I uninstalled AfterShot Pro 2, then bought a license for AfterShot Pro 3 and installed it.
Working great for me. No crashes.
Re: ASP-3 and Linux
Is it true that one cannot open up images specified on command line? I only tested the trial, and it seems that I will have to click a lot on the gui to open up any image, instead just giving the images to be edited on command line when starting up AfterShot3 (the way it worked on earlier versions).
I also get a crash when I browse to a directory with test image converted to jpeg using Aftershot3:
Code: Select all
Scanning file "/tmp/as/PA010182.jpg"
Importing: "/tmp/as/PA010182.jpg"
TIFF Error: /tmp/as/PA010182.jpg "Not a TIFF file, bad magic number 55551 (0xd8ff)"
defaults: "DefaultRendered.xmp"
Segmentation fault
alphadingo
- motherboard: Macbook Pro Retina 2013
Re: ASP-3 and Linux
Fedora 23 on a macbook pro with no issues so far. Any plans for Hi-DPI support? Everything is so tiny. Also, open CL isn't seeing my nvidia card. Any way to fix that?
dFlyer
- System_Drive: N/A
Re: ASP-3 and Linux
That is pretty much the error I was receiving when entering a directory that I use ASP2.4 on. A work around on a test directory was to remove all xmp's, doing so allowed me to edit the file. I'm not sure if that is the way I want proceed as I've got close to 100,000 files in 1000's of directories.
Thanks.
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
Gary Garibaldi
Linux since 96
Sony a700
Sony a100
- nick-in-wales
- System_Drive: N/A
- processor: Intel i5 4690
- ram: 24GB
- Hard_Drive_Capacity: 3TB
- Corel programs: Aftershot Pro 3.
Re: ASP-3 and Linux
I'm sorry to report that I paid up for v.3 and now I've reverted to v.2, hopefully temporarily.
Firstly the much vaunted "Get More" facility is not available under Linux (thanks Gary for the info), but the killer for me was that support for PEF files (Pentax RAW format) seems to have vanished into thin air!
Initially I installed v.3 in parallel with v.2 (not clever I know) and v.3 kept falling over, I then uninstalled both packages moved my user folder and catalogs somewhere safe and re-installed v.3 on it's own, it was at this point I was told the "Get More" tab is a feature not required by Linux users. Still no PEF support but at least it was stable(ish). I am usually cautious hence I stick with a Ubuntu LTS so why I jumped to v.3 on day one beats me.
I will give Corel a few days to come back to me on the PEF issue (it IS supported in v.3 according to Corel), after that I might start thinking about a refund.
Pentax and Ricoh for Ever!
I love Linux!!
It's wet in Wales, always.
I love Linux!!
gewb
- motherboard: MSI Pro B550-VC
- processor: AMD Ryzen 7 5700X
- Video Card: ASRock Radeon RX 6650 XT
- Monitor/Display Make & Model: LG 24MK430
- Corel programs: 2018, 2021, 2023 Ult.
Re: ASP-3 and Linux
I loaded the trial version in Linux Mint 17.3 hoping to get further away from Windows and Adobe.
Main issue is ASP3 doesn't see the mounted NTFS and FAT32 drives which is where my image files are stored. It sees /mnt but nothing in it. Select > RtClick >Refresh didn't help.
Anyone else have this issue?
GEWB
GEWB
Greg Wood
Re: ASP-3 and Linux
Just FYI, we're watching this string and will investigate.
- nick-in-wales
- System_Drive: N/A
- ram: 24GB
Re: ASP-3 and Linux
gewb wrote:I loaded the trial version in Linux Mint 17.3 hoping to get further away from Windows and Adobe.
GEWB
I find I have to open (mount) my NTFS drives with a file explorer after a reboot before Aftershot can see the files, twas scary first time it happened.
I love Linux!!
I love Linux!!
gewb
Re: ASP-3 and Linux
Hello Nick -nick-in-wales wrote:gewb wrote:I loaded the trial version in Linux Mint 17.3 hoping to get further away from Windows and Adobe.
GEWB
Did that (pretty much SOP with any OS), still no joy.
GEWB
(using Linux since 1999, Windows since 1988)
Dutchmm
- System_Drive: N/A
- motherboard: Asus 97
- processor: Intel i7 4785T
- Video Card: Onboard Intel
- sound_card: Intel AC97
- Hard_Drive_Capacity: 2.5TB
- Monitor/Display Make & Model: Philips 28"
- Corel programs: ASP 3 Pro (and 2 and 1 before)
Re: ASP-3 and Linux
I would expect the "foreign" file systems to be mounted at /media/gewb/ on Mint 17.3 - at least that is where they mount on my Mint boxes, and I have no recollection of having changed the defaults.gewb wrote:I loaded the trial version in Linux Mint 17.3 hoping to get further away from Windows and Adobe.
GEWB
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
Re: ASP-3 and Linux
@Greg
On the ASP Facebook page there are several Linux Mint 17.x users who report constant crashes when trying to open directories.
I use this version myself but haven't installed / bought the upgrade yet, because of these crashes.
onnoschmidt
- System_Drive: N/A
Re: ASP-3 and Linux
The underlying framework QT supports setting pixel per ratio to make aftershot a little more usable on hidpi screens.alphadingo wrote:Fedora 23 on a macbook pro with no issues so far. Any plans for Hi-DPI support? Everything is so tiny. Also, open CL isn't seeing my nvidia card. Any way to fix that?
Start aftershot with and many elements will appear bigger.
export QT_DEVICE_PIXEL_RATIO=2;AfterShot3X64
Menu fonts are still small though.
gewb
Re: ASP-3 and Linux
Thanks for your reply, it got me to thinking.Dutchmm wrote: I would expect the "foreign" file systems to be mounted at /media/gewb/ on Mint 17.3 - at least that is where they mount on my Mint boxes, and I have no recollection of having changed the defaults.
Both of my default installations of Mint have my drives mounted as /media so if ASP3 looks to /mnt it will not find anything. I have not found a setting or preference in ASP3 to change locations.
I'll try changing one of my test bed installations to locate the drives in /mnt or I might install a different distro when I have time.
GEWB
