Corel PaintShop Pro X8 Workspace Brightness/Contrast
AnunRhama
Post by AnunRhama »
Hey, I downloaded a trial version of X8, and one of the things that caught my eye is... what's with the values of the workspace in the program? If I open up an Image that is somewhat darker in nature, the software darkens it even further. At least while you are working on it. I've tried increasing the color depth to 16-bit, cause it wasn't on automatic, but no change. If I export it as a PNG (for instance), it becomes brighter in values. And that's how it's everywhere. If I open it in Chrome, any other image viewer/editor program. Just in X8, while working on it, it's darker. It's a problem, not being able to see a final product until you export it at the end. Also, you can see the change when you hover with the mouse over the X8 icon on the taskbar. It displays the tabs of the files you are working on. And if you place a cursor over the tab, it shows you the image with it's real values. Here are the examples:
(These are images from the web, and I had to post links cause of the size)
http://s19.postimg.org/5g80d3akx/1_A.png
http://s19.postimg.org/3pozblt1t/1_B.png
http://s19.postimg.org/bjpkx00up/2_A.png
http://s19.postimg.org/liajjhaa9/2_B.png
Comparison:
http://s19.postimg.org/c5ejt3vwz/comparison.png
So, what's going on. I had some previous versions of PaintShop Pro, and this never happened. Can something be done about this... or is this just a new 'feature'.
Thanx in advance.
AnunRhama
Re: Corel PaintShop Pro X8 Workspace Brightness/Contrast
Post by AnunRhama »
Found it. Went to File> Color Management> Color Management... And then unchecked 'Enable Color Management'. I've never used this before, but it seems that in previous versions, although enabled, it didn't had that much of an effect... as set on default. If someone has something more to add to this, some kind a tip for these values, you're welcomed...
flagpole
motherboard: Gigabyte B450 AORUS ELITE DDR4 USB 3.1 RGB
processor: Ryzen 2600
Video Card: RTX 2060
sound_card: on board
Hard_Drive_Capacity: 6.5TB
Monitor/Display Make & Model: Iiyama 27"
Post by flagpole »
I'll be honest. I have no clue what you are talking about
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
AnunRhama wrote:Found it. Went to File> Color Management> Color Management... And then unchecked 'Enable Color Management'. I've never used this before, but it seems that in previous versions, although enabled, it didn't had that much of an effect... as set on default. If someone has something more to add to this, some kind a tip for these values, you're welcomed...
Color Management is definitely not a strong suit of PSP. Most people find that disabling it (as you did) works best for them also.
JoeB
Using PSP 2019 64bit
GMack
motherboard: MSI MS-1782 REV 1.0
processor: 2.60 gigahertz Intel Core i7-6700HQ
ram: 24 GB
Video Card: NVIDIA GeForce GTX 980M
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Generic PnP Monitor, Eizo CG248 24.0"
Corel programs: Paintshop Pro X8, Aftershot 2
Post by GMack »
Joe's right, color management isn't PSP's strong point and one reason I cannot rely on it for editing-to-print. It's just different from Adobe's PS color management which leaves the default settings alone. Gamma seems to be another PSP issue since my other Eizo monitor tattles on PSP about it changing both gamma and color space when launching it.
You found the issue with the blacks as well. I had some issues between PSP and Photoshop where PS produces a blacker black, and PSP crushes the blacks or perhaps they are more gray than a deep black. I have comparison images of PSP and PS here: http://forum.corel.com/EN/viewtopic.php ... 15#p321196 and a little later on in the same thread.
Also, I know every time nVidia puts out a new driver, I have to set it to the YCbCr444 setting manually or the black detail is gone. Seems nVidia has some preference for TV/movies rather than good screen shadow detail with a RGB=16-235 rather than 0-255 which I have to set manually in their console. Too bad it can't leave those settings alone when it installs a new driver, but that one's for nVidia to fix.
Mack
