1. Photoexplorer 8.5 leaves avi files files open, even without viweving the avi, just browsing to the folder for preview, I can't delete files later without closing PEX8.5 first. Also File explorer can't delete these files ...
Sometimes it has happened also to jpg files.
2. When I open 2 folder trees and delete a file from one subfoldfer, then the other folder tree is closed instantly and I have to navigate back to the second folder to open it each time again. Very tedious.
Robert
files left open
2log
re: files left open
Try reinstalling Photo Explorer. There might just be something wrong with the installed program files on your computer.
When you install a software, the installer extracts temporary files needed for the installation on a temp folder. These folders are usually:
C:\Windows\Temp
C:\Documents and Settings\[User Name]\Local Settings\Temp
If the temp folder holds old installer files that may be corrupted or are duplicates with the same filename but are used for a different software, it could cause a problem for your new installation of the software. Before you reinstall the software, make sure to clean the Temp folders.
The Local Settings folder is a hidden folder so you have to enable Windows Explorer to see hidden files and folders. Open Windows Explorer, go to Tools > Folder Options > View and check show hidden files and folders. You can now open the Temp folder from the Documents and Settings folder and delete the files there before you make a new install.
C:\Windows\Temp
