Hello.
How can I adjust Transitions in my favorites? I mean not when it is already on a timeline! I need to change it before I put it on the timeline. In other way I will be forced to change from 400 to 1000 transition manually on the timeline. I use only Crossfade. I have no idea how can I change all of them at the same time. Transition time is inappropriate for me. I want to decrease it's time.
Custom Transition
redlkb
- motherboard: Acer VA50_HC_CR Type2
- processor: Core i7-3630QM
- Video Card: 640GT
- Hard_Drive_Capacity: 3211.14 GB
- Monitor/Display Make & Model: Acer V3-571G display 15.6' Full HD
- Corel programs: VideoStudio Pro X8
- RobertOZ
- Hard_Drive_Capacity: 7 TB
Re: Custom Transition
If you only use Cross fade, go to Settings/Preferences/Edit
Under Transition effect, tick Automatically add transition effect, then click the down arrow on Default transition effect and select F/x crossfade
If you want the duration to be less than 1 second, this can only be done in the timeline
