did someone found out how to use curves from gimp with aftershot?
Thanks for your help
Aftershot & Courves
PeterMarxen
- System_Drive: N/A
slm
- System_Drive: N/A
- motherboard: Hewlett Packard
- processor: Intel E8400
- ram: 4GB
- Video Card: NVidia Quadro NVS 290
- Monitor/Display Make & Model: Dell U2312HM
- Corel programs: AftershotPro
Re: Aftershot & Courves
Wouldn't this simply be a case of making your adjustments in each program separately ?
Peter,
while the idea might be viable the two programs work quite differently:
ASP is working in a wide-dynamic 16bit colorspace,
the curves are at a fixed point in the pipeline but not the last step.
while the gimp is still 8bit only and the curves are always applied to the image as is.
so that same curve would lead to different results.
which in turn makes an exchange pretty much useless.
Bibble since 2004. Aftershot until 2020. From then on darktable.
