Do KPT Filters come with PSP X8?
cookie1234
Monitor/Display Make & Model: Dell UltraSharp 25 Monitor
Corel programs: PaintShop Pro 2018 Ultimate
Post by cookie1234 »
I read varying posts re: the inclusion of KPT filters in PSP X8. Do they or don't they come with X8 download?
I am using PSP X6 Ultimate and rely VERY heavily on the KPT filters that came with it.
If KPT filters DO come with X8, are they that same ones that are in X6?
(I searched the Web but cannot find a listing of such filters for X8; and the Corel
site doesn't seem to mention them in the advertisement for purchasing X8.)
Radim
ram: 4GB
Monitor/Display Make & Model: 27 inch
Re: Do KPT Filters come with PSP X8?
Post by Radim »
You can get it here, it's free download:
http://www.paintshoppro.com/en/support/ ... pspx8.html
cookie1234
Thank You! I'm going to try to transfer my KPT filters with custom settings to X8; but if it
doesn't work, I'll certainly try that.
JoeB
operating_system: Windows 8.1
ram: 8 GB
Hard_Drive_Capacity: 4.6 TB
Post by JoeB »
cookie1234 wrote:Thank You! I'm going to try to transfer my KPT filters with custom settings to X8; but if it
You don't have to do anything with your presently installed KPT filters. They are a separate program from PSP. When you install X8 you just have to point it to the location of the existing KPT filters (File>Preferences>File Locations). Installing X8 is NOT going to change any preset settings in your existing KPT filters.
JoeB
Using PSP 2019 64bit
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
Note however that if you delete that earlier version of PSP which is associated with those KPT files then they will be removed as well as they are found in the Programs files.
eg in my PSP X4 on Windows XP the location of the KPT Filters is:
C:\Program Files\Corel\Corel PaintShop Pro X4\Languages\EN\PlugIns\KPT
and my PSP X7 is
C:\Program Files\Corel\Corel PaintShop Pro X7\PlugIns\EN\KPT
So if I uninstalled PSP X7 or X4 then I would lose the KPT filters.
JoeB
ram: 8 GB
Post by JoeB »
hartpaul wrote:Note however that if you delete that earlier version of PSP which is associated with those KPT files then they will be removed as well as they are found in the Programs files.
eg in my PSP X4 on Windows XP the location of the Nik Filters is:
and my PSP X7 is
That's a good point, @hartpaul. I wasn't considering that he might actually uninstall his present x6 version where KPT is already installed. If he doesn't uninstall X6 then he could still point X8 to the plugins folder of X6.
In your case, however, if you uninstalled X4 OR X7 you would only lose the plugins folder from the one you uninstalled and could point a newly installed PSP version to the plugins folder of the one you didn't uninstall. If you uninstall both X4 AND X7 then you would lose access to the plugins. :-)
JoeB
Rick_R
motherboard: ASUSTeK Computer INC F2A85-V Pro
processor: AMD A6-6400K APU
Video Card: PowerColor AMD Radeon R7 240 2GB DDR3
sound_card: On-board Realtek and AMD High Definition Audio
Hard_Drive_Capacity: 16TB+375GB
Monitor/Display Make & Model: SEIKI SE39UY04 39in 4K UHD TV
Corel programs: PaintShop Pro 12-2022 Ultimate
Post by Rick_R »
and my PSP X7 is
I have found that in general you can copy PSP plugins from one version to another and they will work. So, create a separate folder specifically for PSP plugins and then whenever you install any PSP version, copy its plugins to that folder and then point your plugins file location to that folder. When you delete that PSP version, the copied plugins will not be deleted. And they will work with the newer versions without needing to be reinstalled.
